@philippv @jacotec @minorspew see Milton’s post here Update on Registration Requirement to Utilize Push Gateway referring to https://github.com/sponsors/RocketChat for available packages, if 10k (or 15k) is enough you should be all set
Okay, after I donate 5$, what do I do next? How do I get a reward?
@sleepawalker.white no idea, ask @milton.rucks or @gabriel.engel
Wanted to know how I buy increase push limit as well as how do we claim it.
According to the current guidelines:
Apps created from a commercialized template or app generation service will be rejected unless they are submitted directly by the provider of the app’s content.
If you build from the single-server branch and make sure the app uses your server, then you are the provider of the app’s content.
Once you do the sponsorship on GitHub, you can goto https://sponsorship.rocket.chat to link it to your workspace
I followed the link above and think that this looks like what we are looking for. However, after pressing the button “Rocket.Chat Cloud” under Sponsorship Benefits
I get the following error:
I’m not sure how to proceed now? I tried several times.
Good Morning,
we would like to upgrade our push messages. Where we can find some informations what we have to do?
Cloud connection is established and credit card is also on the panel.
Thanks a lot.
Seriously? If you’re self-hosting there’s no way to get notifications on the Rocket.Chat iOS app?
You will need to register a workspace to enable push notifications through the Rocket.Chat gateway.
As above you get 10k for free, then a couple of increases in notification quantities for small levels of sponsorship through github.
Beyond that you can either use a subscription, or use your own notification gateway. But to do that you will need to build and run your own apps.
