Wizard showing blank screen
I created a Digital Ocean Droplet following these instructions: [Rocket.Chat
I added my dns and then installed the ssl certificate. But when i check on the wizard home page it loads, you can see the rocket.chat logo but its is blank,
This is my url please have a look; www.teqcord.com
  • Operating System:
  • Deployment Method:
  • NodeJS Version:
  • MongoDB Version:
  • Proxy:
Sorry for the late response. Have you solved this issue?
No, it had me up all night, im not the one to gave up but i had to looool. Found a next media chat that i use. But thatnk you for getting back, and from what i seen this looks like a big problem
I would go the route of installing directly using docker.
I have done tons of deployment directly with docker, and doesn’t face this problem.
One Click deployment are good way to easily deploy, but docker is a better approach to have more controle over the environment, and also to have the same environment as most of the users around.
Thank you for tje insight. But i jad to find a next chat group. Thank you anyway
