Only blank page after following Docker Containers installation guide
I followed the guide at:
https://docs.rocket.chat/quick-start/installing-and-updating/docker-containers#6.-create-the-docker-compose.yml-file-and-local-directories
as close as possible, installing rocket chat on my VPS server. I used the certbot for step 5 and thus skipped b and c.
HTTPS itself seems to work, but when I try to visit the rocket.chat server in the browser I just get an empty blank page.
I added the nginx conf files and the docker-compose.yml below. Do you need any additional info?
  • Version of Rocket.Chat Server: latest (cant see it yet since i cannot login/view the server)
  • Operating System: Debian 10
  • Deployment Method: docker
  • DB Replicaset Oplog: ?
  • NodeJS Version: ?
  • MongoDB Version: 4.0
  • Proxy: nginx
  • Firewalls involved: theoretically ufw, but disabled right now
/etc/nginx/nginx.conf
user www-data;
worker_processes auto;
pid /run/nginx.pid;
include /etc/nginx/modules-enabled/*.conf;
events {
        worker_connections 768;
        # multi_accept on;
http {
        # Basic Settings
        sendfile on;
        tcp_nopush on;
        tcp_nodelay on;
        keepalive_timeout 65;
        types_hash_max_size 2048;
        # server_tokens off;
        # server_names_hash_bucket_size 64;
        # server_name_in_redirect off;
        include /etc/nginx/mime.types;
        default_type application/octet-stream;
        # SSL Settings
        ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
        ssl_prefer_server_ciphers on;
        # Logging Settings
        access_log /var/log/nginx/access.log;
        error_log /var/log/nginx/error.log;
        # Gzip Settings
        gzip on;
        # gzip_vary on;
        # gzip_proxied any;
        # gzip_comp_level 6;
        # gzip_buffers 16 8k;
        # gzip_http_version 1.1;
        # gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
        # Virtual Host Configs
        include /etc/nginx/conf.d/*.conf;
        include /etc/nginx/sites-enabled/*;
#mail {
#       # See sample authentication script at:
#       # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#       # auth_http localhost/auth.php;
#       # pop3_capabilities "TOP" "USER";
#       # imap_capabilities "IMAP4rev1" "UIDPLUS";
#       server {
#               listen     localhost:110;
#               protocol   pop3;
#               proxy      on;
#       server {
#               listen     localhost:143;
#               protocol   imap;
#               proxy      on;
/etc/nginx/sites-available/default
# You should look at the following URL's in order to grasp a solid understanding
# of Nginx configuration files in order to fully unleash the power of Nginx.
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
# Please see /usr/share/doc/nginx-doc/examples/ for more detailed examples.
# Virtual Host configuration for example.com
# You can move that to a different file under sites-available/ and symlink that
# to sites-enabled/ to enable it.
#server {
#       listen 80;
#       listen [::]:80;
#       server_name example.com;
#       root /var/www/example.com;
#       index index.html;
#       location / {
#               try_files $uri $uri/ =404;
server {
        # SSL configuration
        # listen 443 ssl default_server;
        # listen [::]:443 ssl default_server;
        # Note: You should disable gzip for SSL traffic.
        # See: https://bugs.debian.org/773332
        # Read up on ssl_ciphers to ensure a secure configuration.
        # See: https://bugs.debian.org/765782
        # Self signed certs generated by the ssl-cert package
        # Don't use them in a production server!
        # include snippets/snakeoil.conf;
        root /var/www/html;
        # Add index.php to the list if you are using PHP
        index index.html index.htm index.nginx-debian.html;
    server_name rocket.jugger-freiburg.de; # managed by Certbot
        location / {
                # First attempt to serve request as file, then
                # as directory, then fall back to displaying a 404.
            proxy_pass http://rocket.jugger-freiburg.de:3000/;
            proxy_http_version 1.1;
            proxy_redirect off;
        # pass PHP scripts to FastCGI server
        #location ~ \.php$ {
        #       include snippets/fastcgi-php.conf;
        #       # With php-fpm (or other unix sockets):
        #       fastcgi_pass unix:/run/php/php7.3-fpm.sock;
        #       # With php-cgi (or other tcp sockets):
        #       fastcgi_pass 127.0.0.1:9000;
        # deny access to .htaccess files, if Apache's document root
        # concurs with nginx's one
        #location ~ /\.ht {
        #       deny all;
    listen [::]:443 ssl ipv6only=on; # managed by Certbot
    listen 443 ssl; # managed by Certbot
    ssl_certificate /etc/letsencrypt/live/rocket.jugger-freiburg.de/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/rocket.jugger-freiburg.de/privkey.pem; # managed by Certbot
    include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
    ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
    if ($host = rocket.jugger-freiburg.de) {
        return 301 https://$host$request_uri;
    } # managed by Certbot
        listen 80 ;
        listen [::]:80 ;
    return 404; # managed by Certbot
docker-compose.yml
version: '2'
services:
  rocketchat:
    image: registry.rocket.chat/rocketchat/rocket.chat:latest
    command: >
      bash -c
        "for i in `seq 1 30`; do
          node main.js &&
          s=$$? && break || s=$$?;
          sleep 5;
        done; (exit $$s)"
    restart: unless-stopped
    volumes:
      - ./uploads:/app/uploads
      - PORT=3000
      - ROOT_URL=http://rocket.jugger-freiburg.de:3000
      - Accounts_UseDNSDomainCheck=false
#       - HTTP_PROXY=http://proxy.domain.com
#       - HTTPS_PROXY=http://proxy.domain.com
    depends_on:
      - mongo
    ports:
      - 3000:3000
    labels:
  mongo:
    image: mongo:4.0
    volumes:
     - ./data/db:/data/db
     #- ./data/dump:/dump
    labels:
      - "traefik.enable=false"
  mongo-init-replica:
    image: mongo:4.0
    command: >
      bash -c
            rs.initiate({
              _id: 'rs0',
          sleep 5;
        done; (exit $$s)"
    depends_on:
      - mongo
  hubot:
    image: rocketchat/hubot-rocketchat:latest
      - ROCKETCHAT_URL=51.68.173.98:3000
      - ROCKETCHAT_ROOM=GENERAL
      - ROCKETCHAT_USER=bot
      - ROCKETCHAT_PASSWORD=botpassword
      - BOT_NAME=bot
      - EXTERNAL_SCRIPTS=hubot-help,hubot-seen,hubot-links,hubot-diagnostics
    depends_on:
      - rocketchat
    labels:
    volumes:
      - ./scripts:/home/hubot/scripts
  # this is used to expose the hubot port for notifications on the host on port 3001, e.g. for hubot-jenkins-notifier
    ports:
      - 3001:8080
  #traefik:
  #  image: traefik:latest
  #  restart: unless-stopped
  #  command: >
  #    traefik
  #     --docker
  #     --acme=true
  #     --acme.domains='your.domain.tld'
  #     --acme.email='your@email.tld'
  #     --acme.entrypoint=https
  #     --acme.storagefile=acme.json
  #     --defaultentrypoints=http
  #     --defaultentrypoints=https
  #     --entryPoints='Name:http Address::80 Redirect.EntryPoint:https'
  #     --entryPoints='Name:https Address::443 TLS.Certificates:'
  #  ports:
  #    - 80:80
  #    - 443:443
  #  volumes:
  #    - /var/run/docker.sock:/var/run/docker.sock
