Not receiving emails anymore so cannot change settings as admin as TOTP is required
  • Operating System: Linux
  • Deployment Method: docker
  • NodeJS Version:
  • MongoDB Version:
  • Proxy:
I had the SMTP settings correctly enabled before but in order to disable the welcome emails users get (despite the setting being switch off) I removed the SMTP settings but unfortunately now my admin account isn’t getting the 2fa codes sent to email when I try to change other settings.
Is there a way I can set the SMTP settings again or disable the 2fa?
By the way, I don’t know why 2fa is enabled for the admin even though I’ve disabled 2fa in the app.
Hi there!
You can overwrite this option by setting some environment variables, such as:
  - OVERWRITE_SETTING_Accounts_TwoFactorAuthentication_Enforce_Password_Fallback=false
  - OVERWRITE_SETTING_Accounts_TwoFactorAuthentication_Enabled=false
You can change almost all configuration using this technique.
You can also change directly from the database, if you know how to do it:
please, let me know if this worked for you.
Thanks!!
Hey thanks for your response!
Unfortunately I ended up just resetting my server by deleting all rocketchat collections
