When we try to upgrade mongodb from version 4.4 we have some javascript client side issues (message not marked as read or as unread, server registration for example) we have to refresh manually the client (browser or electron) to update the display.
The problem appears from Mongodb version 5.x, if we rollback to version 4.4, it returns to normal.
We reproduced the issue on a fresh debian bookworm install with kiss configuration of nginx and mongodb with latest recommended versions.
Could you reproduce and investigate please ?
Thank you in advance.
Version of Rocket.Chat Server: 7.4.1
Operating System: Debian GNU/Linux12 (Bookworm)
Deployment Method: tar or docker
DB Replicaset Oplog: wiredTiger (oplog Activated)
NodeJS Version: v22.13.1 - x64
MongoDB Version: > 5.0
Proxy: nginx
Firewalls involved: turned off
| SERVER RUNNING |
| Rocket.Chat Version: 7.4.1 |
| NodeJS Version: 22.13.1 - x64 |
| MongoDB Version: 7.0.17 |
| Platform: linux |
| Process Port: 3000 |
| Site URL: http://my_ip |
| ReplicaSet OpLog: Enabled |
| Commit Hash: fb0f4eaf59 |
| Commit Branch: HEAD |
Steps to reproduce the issue
# apt install g++ build-essential git curl python3 docker docker.io graphicsmagick nginx nginx-full nginx-core rsync
# curl -fsSL https://deb.nodesource.com/setup_22.x -o nodesource_setup.sh
# chmod +x nodesource_setup.sh
# bash nodesource_setup.sh
# aptitude install nodejs=22.13.1-1nodesource1
# aptitude hold nodejs
# echo "{\"iptables\": false}" > /etc/docker/daemon.json
# iptables -t nat -A POSTROUTING ! -o docker0 -s 172.17.0.0/16 -j MASQUERADE
# npm install --global yarn
# useradd -M rocketchat && usermod -L rocketchat
# mkdir -p /backups/rocketchat/mongodb /backups/rocketchat/wwwroot/ /backups/rocketchat/mongodb/datas /backups/rocketchat/wwwroot/bundle/
# chown -R rocketchat:rocketchat /backups/rocketchat/wwwroot/
$ curl -fsSL https://deno.land/install.sh | sh
$ curl https://install.meteor.com/?release=2.0 | sh
$ curl -L https://releases.rocket.chat/latest/download -o /tmp/rocket.chat.tgz
$ tar -xzf /tmp/rocket.chat.tgz -C /tmp
$ export NODE_EXTRA_CA_CERTS=/etc/ssl/certs/ca-certificates.crt
$ cd /tmp/bundle/programs/server && npm install --unsafe-perm
$ rsync -avh /tmp/bundle/ /backups/rocketchat/wwwroot/bundle/
# docker pull mongo:7.0
# nano /etc/systemd/system/docker-mongodb.service
[Unit]
Description=MongoDB - docker container
After=docker.service
BindsTo=docker.service
[Service]
StandardOutput=append:/var/log/docker-mongodb/mongodb.log
StandardError=append:/var/log/docker-mongodb/mongodb.log
Environment=NAME=mongodb_container
Environment=IMAGE=mongo:7.0
Environment=PORT=27017
Environment=MONGODB_DIR=/backups/rocketchat/mongodb
Restart=on-failure
RestartSec=10
ExecStartPre=-/usr/bin/docker kill ${NAME}
ExecStartPre=-/usr/bin/docker rm ${NAME}
ExecStart=/usr/bin/docker run -p ${PORT}:${PORT} -v ${MONGODB_DIR}/datas:/data/db -v ${MONGODB_DIR}/dumps:/dump -v ${MONGODB_DIR}/files:/opt/files --name ${NAME} ${IMAGE} --oplogSize 128 --replSet rs01 --storageEngine=wiredTiger
ExecStop=/usr/bin/docker stop ${NAME}
[Install]
WantedBy=multi-user.target
# systemctl daemon-reload
# mkdir /var/log/docker-mongodb/
# service docker-mongodb start
# docker exec -it mongodb_container mongosh --host localhost --port 27017
> rs.initiate({_id: "rs01",members: [{_id: 0,host:"127.0.0.1:27017"}]})
# nano /etc/systemd/system/rocketchat.service
[Unit]
After=network.target remote-fs.target nss-lookup.target nginx.service docker-mongod.service
[Service]
User=rocketchat
StandardOutput=append:/var/log/rocketchat/prod.log
StandardError=append:/var/log/rocketchat/prod.log
ExecStart=/usr/bin/node /backups/rocketchat/wwwroot/bundle/main.js
Environment=ROOT_URL=http://my_ip
Environment=PORT=3000
Environment=BIND_IP=my_ip
Environment=INSTANCE_IP=my_ip
Environment=NODE_EXTRA_CA_CERTS=/etc/ssl/certs/ca-certificates.crt
Environment=MONGO_URL=mongodb://127.0.0.1:27017/rocketchat?replicaSet=rs01&readPreference=primaryPreferred&w=1
Environment=MONGO_OPLOG_URL=mongodb://127.0.0.1:27017/local?replicaSet=rs01
Environment=USE_NATIVE_OPLOG=true
Restart=on-failure
RestartSec=10
[Install]
# mkdir /var/log/rocketchat/
# nano /etc/nginx/sites-available/rocketchat
server {
listen 0.0.0.0:80;
rewrite_log off;
access_log /var/log/nginx/rocketchat_access.log;
error_log /var/log/nginx/rocketchat_error.log;
client_max_body_size 5M;
root /dev/null;
location / {
proxy_pass http://backend.rocket;
proxy_http_version 1.1;
proxy_redirect off;
# nano /etc/nginx/sites-available/rocketchat.backend
upstream backend.rocket {
server my_ip:3000;
# rm -rf /etc/nginx/sites-enabled/default
# ln -s /etc/nginx/sites-available/rocketchat /etc/nginx/sites-enabled/rocketchat
# ln -s /etc/nginx/sites-available/rocketchat.backend /etc/nginx/sites-enabled/rocketchat.backend
# nginx -t
# service nginx reload
# service rocketchat start
# tail -f /var/log/rocketchat/prod.log
