I have upgraded my mongoDB from 4.0.28 to 4.2, then 4.4, then 5.0. After restarting rocketchat, I am still getting the deprected mongoDB warning, even though the correct mongoDB version is listed in info
- Version of Rocket.Chat Server: 4.6.3
- Operating System: Ubuntu 18
- Deployment Method: docker
- DB Replicaset Oplog:
- NodeJS Version:
- MongoDB Version: 5.0.9
- Proxy: nginx
- Firewalls involved:
Hi! Welcome to our community!
Well… That should not happen
Would you mind sharing your docker-compose.yml so I can try reproducing it here?
Have you just changed version from the default one?
Thanks for getting back to me. So we are pretty new to rocket chat. Yesterday I went through the process of getting mongodb updated to remove that warning and just generally be prepared for the future. That process went quite smoothly.
After updating the 4.0.28 we were on to 4.2, the warning went away. Or I should say it didn’t return. After updating to 4.4 it didn’t return. After 5.0, it did show back up again. I rebooted rocketchat, and it showed up again.
This morning however, after another reboot before responding to this message, it didn’t show up? What is strange is we have a second rocketchat server and that server the message went away after the update from 4.0 to 4.2 and we never saw it again.
So, all that together, I have to think I was just seeing some left over message somehow from before the update. Perhaps some network delay between our server and the client.
I am not sure there is anything to do here, but I am glad to share the docker-compose.yml if you still want it. Otherwise, I think we can close this
Oh, glad to hear it
We are targeting Mongo 4.4 for now, as 5.0 is causing some CPU incompatibilities here and there ( MongoDB 5.0+ requires a CPU with AVX support)
You can check our Mongo Compatibility Matrix Here
Also, consider joining our Community Support Channel in our open server
aaaand participating in our Monthly Community Open Call
Thanks!!
