My hard drive died on which there was a chat directory. But I have a lot of backups, but I can’t use them, the container doesn’t start, although nothing has changed in essence. Here is the database log.
mongodb 17:45:57.24 INFO ==> ** Starting MongoDB **
{"t":{"$date":"2023-08-23T17:45:57.308Z"},"s":"I", "c":"CONTROL", "id":5760901, "ctx":"-","msg":"Applied --setParameter options","attr":{"serverParameters":{"enableLocalhostAuthBypass":{"default":true,"value":true}}}}
{"t":{"$date":"2023-08-23T17:45:57.309+00:00"},"s":"I", "c":"CONTROL", "id":20698, "ctx":"-","msg":"***** SERVER RESTARTED *****"}
{"t":{"$date":"2023-08-23T17:45:57.311+00:00"},"s":"I", "c":"NETWORK", "id":4915701, "ctx":"main","msg":"Initialized wire specification","attr":{"spec":{"incomingExternalClient":{"minWireVersion":0,"maxWireVersion":17},"incomingInternalClient":{"minWireVersion":0,"maxWireVersion":17},"outgoing":{"minWireVersion":6,"maxWireVersion":17},"isInternalClient":true}}}
{"t":{"$date":"2023-08-23T17:45:57.315+00:00"},"s":"I", "c":"CONTROL", "id":23285, "ctx":"main","msg":"Automatically disabling TLS 1.0, to force-enable TLS 1.0 specify --sslDisabledProtocols 'none'"}
{"t":{"$date":"2023-08-23T17:45:57.316+00:00"},"s":"I", "c":"NETWORK", "id":4648601, "ctx":"main","msg":"Implicit TCP FastOpen unavailable. If TCP FastOpen is required, set tcpFastOpenServer, tcpFastOpenClient, and tcpFastOpenQueueSize."}
{"t":{"$date":"2023-08-23T17:45:57.321+00:00"},"s":"I", "c":"REPL", "id":5123008, "ctx":"main","msg":"Successfully registered PrimaryOnlyService","attr":{"service":"TenantMigrationDonorService","namespace":"config.tenantMigrationDonors"}}
{"t":{"$date":"2023-08-23T17:45:57.321+00:00"},"s":"I", "c":"REPL", "id":5123008, "ctx":"main","msg":"Successfully registered PrimaryOnlyService","attr":{"service":"TenantMigrationRecipientService","namespace":"config.tenantMigrationRecipients"}}
{"t":{"$date":"2023-08-23T17:45:57.321+00:00"},"s":"I", "c":"REPL", "id":5123008, "ctx":"main","msg":"Successfully registered PrimaryOnlyService","attr":{"service":"ShardSplitDonorService","namespace":"config.tenantSplitDonors"}}
{"t":{"$date":"2023-08-23T17:45:57.321+00:00"},"s":"I", "c":"CONTROL", "id":5945603, "ctx":"main","msg":"Multi threading initialized"}
{"t":{"$date":"2023-08-23T17:45:57.323+00:00"},"s":"I", "c":"CONTROL", "id":4615611, "ctx":"initandlisten","msg":"MongoDB starting","attr":{"pid":1,"port":27017,"dbPath":"/bitnami/mongodb/data/db","architecture":"64-bit","host":"rocketchat-db"}}
{"t":{"$date":"2023-08-23T17:45:57.323+00:00"},"s":"I", "c":"CONTROL", "id":23403, "ctx":"initandlisten","msg":"Build Info","attr":{"buildInfo":{"version":"6.0.8","gitVersion":"3d84c0dd4e5d99be0d69003652313e7eaf4cdd74","openSSLVersion":"OpenSSL 1.1.1n 15 Mar 2022","modules":[],"allocator":"tcmalloc","environment":{"distmod":"debian11","distarch":"x86_64","target_arch":"x86_64"}}}}
{"t":{"$date":"2023-08-23T17:45:57.323+00:00"},"s":"I", "c":"CONTROL", "id":51765, "ctx":"initandlisten","msg":"Operating System","attr":{"os":{"name":"PRETTY_NAME=\"Debian GNU/Linux 11 (bullseye)\"","version":"Kernel 4.4.180+"}}}
{"t":{"$date":"2023-08-23T17:45:57.323+00:00"},"s":"I", "c":"CONTROL", "id":21951, "ctx":"initandlisten","msg":"Options set by command line","attr":{"options":{"config":"/opt/bitnami/mongodb/conf/mongodb.conf","net":{"bindIp":"*","ipv6":false,"port":27017,"unixDomainSocket":{"enabled":true,"pathPrefix":"/opt/bitnami/mongodb/tmp"}},"processManagement":{"fork":false,"pidFilePath":"/opt/bitnami/mongodb/tmp/mongodb.pid"},"replication":{"enableMajorityReadConcern":true,"replSetName":"rs0"},"security":{"authorization":"disabled"},"setParameter":{"enableLocalhostAuthBypass":"true"},"storage":{"dbPath":"/bitnami/mongodb/data/db","directoryPerDB":false,"journal":{"enabled":true}},"systemLog":{"destination":"file","logAppend":true,"logRotate":"reopen","path":"/opt/bitnami/mongodb/logs/mongodb.log","quiet":false,"verbosity":0}}}}
{"t":{"$date":"2023-08-23T17:45:57.324+00:00"},"s":"I", "c":"STORAGE", "id":22270, "ctx":"initandlisten","msg":"Storage engine to use detected by data files","attr":{"dbpath":"/bitnami/mongodb/data/db","storageEngine":"wiredTiger"}}
{"t":{"$date":"2023-08-23T17:45:57.324+00:00"},"s":"I", "c":"STORAGE", "id":22315, "ctx":"initandlisten","msg":"Opening WiredTiger","attr":{"config":"create,cache_size=31506M,session_max=33000,eviction=(threads_min=4,threads_max=4),config_base=false,statistics=(fast),log=(enabled=true,remove=true,path=journal,compressor=snappy),builtin_extension_config=(zstd=(compression_level=6)),file_manager=(close_idle_time=600,close_scan_interval=10,close_handle_minimum=2000),statistics_log=(wait=0),json_output=(error,message),verbose=[recovery_progress:1,checkpoint_progress:1,compact_progress:1,backup:0,checkpoint:0,compact:0,evict:0,history_store:0,recovery:0,rts:0,salvage:0,tiered:0,timestamp:0,transaction:0,verify:0,log:0],"}}
{"t":{"$date":"2023-08-23T17:45:59.355+00:00"},"s":"E", "c":"WT", "id":22435, "ctx":"initandlisten","msg":"WiredTiger error message","attr":{"error":1,"message":{"ts_sec":1692812759,"ts_usec":355627,"thread":"1:0x7f5130c4acc0","session_dhandle_name":"file:WiredTiger.wt","session_name":"connection","category":"WT_VERB_DEFAULT","category_id":9,"verbose_level":"ERROR","verbose_level_id":-3,"msg":"__posix_open_file:812:/bitnami/mongodb/data/db/WiredTiger.wt: handle-open: open","error_str":"Operation not permitted","error_code":1}}}
{"t":{"$date":"2023-08-23T17:45:59.370+00:00"},"s":"E", "c":"WT", "id":22435, "ctx":"initandlisten","msg":"WiredTiger error message","attr":{"error":1,"message":{"ts_sec":1692812759,"ts_usec":370656,"thread":"1:0x7f5130c4acc0","session_dhandle_name":"file:WiredTiger.wt","session_name":"connection","category":"WT_VERB_DEFAULT","category_id":9,"verbose_level":"ERROR","verbose_level_id":-3,"msg":"__posix_open_file:812:/bitnami/mongodb/data/db/WiredTiger.wt: handle-open: open","error_str":"Operation not permitted","error_code":1}}}
{"t":{"$date":"2023-08-23T17:45:59.385+00:00"},"s":"E", "c":"WT", "id":22435, "ctx":"initandlisten","msg":"WiredTiger error message","attr":{"error":1,"message":{"ts_sec":1692812759,"ts_usec":385236,"thread":"1:0x7f5130c4acc0","session_dhandle_name":"file:WiredTiger.wt","session_name":"connection","category":"WT_VERB_DEFAULT","category_id":9,"verbose_level":"ERROR","verbose_level_id":-3,"msg":"__posix_open_file:812:/bitnami/mongodb/data/db/WiredTiger.wt: handle-open: open","error_str":"Operation not permitted","error_code":1}}}
{"t":{"$date":"2023-08-23T17:45:59.387+00:00"},"s":"W", "c":"STORAGE", "id":22347, "ctx":"initandlisten","msg":"Failed to start up WiredTiger under any compatibility version. This may be due to an unsupported upgrade or downgrade."}
{"t":{"$date":"2023-08-23T17:45:59.387+00:00"},"s":"F", "c":"STORAGE", "id":28595, "ctx":"initandlisten","msg":"Terminating.","attr":{"reason":"1: Operation not permitted"}}
{"t":{"$date":"2023-08-23T17:45:59.388+00:00"},"s":"F", "c":"ASSERT", "id":23091, "ctx":"initandlisten","msg":"Fatal assertion","attr":{"msgid":28595,"file":"src/mongo/db/storage/wiredtiger/wiredtiger_kv_engine.cpp","line":708}}
{"t":{"$date":"2023-08-23T17:45:59.388+00:00"},"s":"F", "c":"ASSERT", "id":23092, "ctx":"initandlisten","msg":"\n\n***aborting after fassert() failure\n\n"}
mongodb 17:46:00.67
mongodb 17:46:00.67 Welcome to the Bitnami mongodb container
mongodb 17:46:00.68 Subscribe to project updates by watching https://github.com/bitnami/containers
mongodb 17:46:00.68 Submit issues and feature requests at https://github.com/bitnami/containers/issues
mongodb 17:46:00.68
mongodb 17:46:00.68 INFO ==> ** Starting MongoDB setup **
mongodb 17:46:00.73 INFO ==> Validating settings in MONGODB_* env vars...
mongodb 17:46:00.80 WARN ==> You set the environment variable ALLOW_EMPTY_PASSWORD=1. For safety reasons, do not use this flag in a production environment.
mongodb 17:46:00.82 INFO ==> Initializing MongoDB...
mongodb 17:46:00.87 INFO ==> Deploying MongoDB with persisted data...
mongodb 17:46:00.91 INFO ==> ** MongoDB setup finished! **
Version of Rocket.Chat Server: 6.3.1
Operating System: synology
Deployment Method: docker
DB Replicaset Oplog: Enabled
NodeJS Version: 14.21.3
MongoDB Version: 6.0.8
