Ok so, I created a rocket chat server and set up all the necessary information (channels, users, custom css…etc), I followed the documentation to create a backup of this mongoDB database container and dump into another MongoDB container (for testing)
here are the commands I used, the backup container is called “db” and the one i want to dump the data into is named “mongo”.
docker exec db sh -c “mongodump --archive” > db.dump
docker exec -i mongo sh -c “mongorestore --archive” < db.dump
So far so good, the operation was successful as the command, as confirmed by the logs
the problem is when i try running a rocket chat container that uses the second mongo container
Expected behavior
when running the rocket chat container, I should be able to at least login with the users stored previous database
Actual behavior
The rocket chat container behaves as if I’m running it for the first time, taking me to the setup wizard.
- Version of Rocket.Chat Server: 5.2.0
- Operating System: windows 10 pro
- Deployment Method: docker
- DB Replicaset Oplog: enabled
- NodeJS Version: 14.19.3
- MongoDB Version: 4.4
- Firewalls involved: none
