Trouble in setting up Rocket chat locally
I am new to open source. I am currently trying to contribute to the Rocket chat project but I am facing some issues while setting it up locally on my system.
I am getting the below error message using the same node and yarn version mentioned.
So kindly can you please guide me how to resolve this issue.
  • Operating System: Windows 64bit
  • Deployment Method:
  • NodeJS Version: 14.19.3
  • MongoDB Version: v5.0.3
  • Proxy:
Hi! Welcome to our Community :slight_smile:
Looks like there is an error in the packages/ui-contexts/src/en.json
these are some symlinks: Rocket.Chat/en.json at develop · RocketChat/Rocket.Chat · GitHub
that will end up here:
This file was recently changed…
make sure you have not changed this file.
A great place to hang around and look for help is also in out Get started channel:
note the fixed message on the banner, it has a nice set of instructions on where to get specific help for environments such as Windows and Mac.
let me know if this helps :slight_smile:
Hey just to be sure are you talking about the change in en.json file(ui-context) or en.18n.json(/apps/meteor) file ? Which file should I not change ?
It’s not that you can’t change.
but something is wrong on that file.
have you changed it?
Also, if you only want to change translations, there is a way of doing it without touching code in General > Translations
