rocketchat server Often collapse
- Version of Rocket.Chat Server: 3.30
- Operating System: Centos8
- Deployment Method: Manual Installation
- DB Replicaset Oplog:
- NodeJS Version: v12.14.0
- MongoDB Version: 4.0.18
- Proxy: nginx
- Firewalls involved:
[root@ChatSvr server]# systemctl status rocketchat
Loaded: loaded (/usr/lib/systemd/system/rocketchat.service; enabled; vendor preset: disabled)
Active: failed (Result: signal) since Wed 2020-06-17 19:22:40 CST; 12h ago
Process: 6744 ExecStart=/usr/local/bin/node /opt/Rocket.Chat/main.js (code=killed, signal=KILL)
Main PID: 6744 (code=killed, signal=KILL)
Jun 17 16:46:02 ChatSvr rocketchat[6744]: at Pool.destroy (/opt/Rocket.Chat/programs/server/npm/node_modules/meteor/npm-mongo/node_modules/mongodb/lib/core/connection/pool.js:678:21)
Jun 17 16:46:02 ChatSvr rocketchat[6744]: at Server.destroy (/opt/Rocket.Chat/programs/server/npm/node_modules/meteor/npm-mongo/node_modules/mongodb/lib/core/topologies/server.js:902:15)
Jun 17 16:46:02 ChatSvr rocketchat[6744]: at Timeout._onTimeout (/opt/Rocket.Chat/programs/server/npm/node_modules/meteor/npm-mongo/node_modules/mongodb/lib/core/topologies/replset.js:356:26)
Jun 17 16:46:02 ChatSvr rocketchat[6744]: at listOnTimeout (internal/timers.js:531:17)
Jun 17 16:46:02 ChatSvr rocketchat[6744]: at processTimers (internal/timers.js:475:7) {
Jun 17 16:46:02 ChatSvr rocketchat[6744]: name: 'MongoError',
Jun 17 16:46:02 ChatSvr rocketchat[6744]: [Symbol(mongoErrorContextSymbol)]: {}
Jun 17 16:46:02 ChatSvr rocketchat[6744]: }
Jun 17 19:22:40 ChatSvr systemd[1]: rocketchat.service: Main process exited, code=killed, status=9/KILL
Jun 17 19:22:40 ChatSvr systemd[1]: rocketchat.service: Failed with result 'signal'.
[root@ChatSvr nginx]# systemctl status rocketchat
Active: failed (Result: signal) since Fri 2020-06-19 18:21:46 CST; 1h 26min ago
Process: 10524 ExecStart=/usr/local/bin/node /opt/Rocket.Chat/main.js (code=killed, signal=KILL)
Main PID: 10524 (code=killed, signal=KILL)
Jun 18 15:24:08 ChatSvr rocketchat[10524]: }
Jun 18 15:24:13 ChatSvr rocketchat[10524]: server.js:204 Push ➔ error Error sending push to gateway (1 try) ->
Jun 18 15:24:13 ChatSvr rocketchat[10524]: at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:60:26) {
Jun 18 15:24:13 ChatSvr rocketchat[10524]: errno: 'ENOTFOUND',
Jun 18 15:24:13 ChatSvr rocketchat[10524]: code: 'ENOTFOUND',
Jun 18 15:24:13 ChatSvr rocketchat[10524]: syscall: 'getaddrinfo',
Jun 18 15:24:13 ChatSvr rocketchat[10524]: hostname: 'gateway.rocket.chat'
Jun 18 15:24:13 ChatSvr rocketchat[10524]: }
Jun 19 18:21:46 ChatSvr systemd[1]: rocketchat.service: Main process exited, code=killed, status=9/KILL
Jun 19 18:21:46 ChatSvr systemd[1]: rocketchat.service: Failed with result 'signal'.
