Silly question.....Rocket.Cat avatar went missing, and it's defaulted to 'R"..How to change?
This is silly… but the rocket.cat avatar has gone missing, and it won’t allow me to change it back as it requires an email address. Any idea how to put it back?
  • Operating System:
  • Deployment Method:
  • NodeJS Version:
  • MongoDB Version:
  • Proxy:
Hi! Welcome to our forums!!
Can you add some fake email? or something like youremail+something@gmail.com
The other option I see is using the API, like in:
@dudanogueira thanks for the reply! When I enter a valid email it just generates an error… so the API thing might be the way to go. Thanks for the idea!
we have been refactoring a lot of the UI for react, so those are happening more then it should :see_no_evil:
What version are you running?
It may be another validation error, so if you open the developer tools, you should see some related logs, on console, or at the network tab.
Also, consider joining our Community Support Channel and participating in our Open Community Call
Looks like version 4.6.2
Let me get my dev on the dev tools thing… as you just went a bit over my admin head…
@dudanogueira thanks for the suggestions… if you think upgrading the server would help?
I’ll try and get some console output for you. Should I provide that info, while trying to save the rocket.cat profile form?
Probably will not change, 4.6.3 doesn’t seem to have touched this modules:
