Hi all!
I would like to ask on whether it’s possible to set up Rocketchat application inside 2 separate VM’s using the free edition license. (I am using Manual Installation Ubuntu guide for this). I am getting “You are operating multiple instances without an active enter
prise license - some features may not behave as designed”
Meaning, instead of having 2 RocketChat instances inside a single VM, I would like to have it separated. 1 RocketChat per VM.
My goal is to have:
- 2 RocketChat VM’s, each VM having it’s own IP but load balanced to a single DNS
- 1 Nginx VM to enable SSL
- 3 MongoDB VM’s, replicaset, both RocketChat VM’s to connect here
Any help is much appreciated, Thanks in advance!
Node 1 VM “systemctl edit rocketchat”
[Service]
Environment=ROOT_URL=http://localhost:3000/
Environment=PORT=3000
#Environment=MONGO_URL=mongodb://192.168.9.205:27017/rocketchat?replicaSet=rs01
#Environment=MONGO_OPLOG_URL=mongodb://192.168.9.205:27017/local?replicaSet=rs01
Environment=MONGO_URL=mongodb://mongo-db1:27017,mongo-db2:27017,mongo-db3:27017/rocketchat?replicaSet=rs01
Environment=MONGO_OPLOG_URL=mongodb://mongo-db1:27017,mongo-db2:27017,mongo-db3:27017/rocketchat?replicaSet=rs01
Node 2 VM “systemctl edit rocketchat”
[Service]
If i have both RC application running in both of my VM’s, only 1 of the VM’s RocketChat application I am able to access
