Hello, i get an error when I connect multiple instances rocketchat server with nginx:
You are operating multiple instances… some features will not behave as
designed.
I have already read all the documentation for rocketchat and a lot of material in the documentation for mongodb))
Steps to play:
1. I’m Install MongoDB Community Edition 5.0.13 (also tried with version 4.4.17)
My config mongodb:
i tried using simple setup:
storage:
dbPath: /var/lib/mongodb
journal:
enabled: true
engine: wiredTiger
systemLog:
destination: file
logAppend: true
path: /var/log/mongodb/mongod.log
net:
port: 27017
bindIp: 127.0.0.1,192.168.10.70
processManagement:
timeZoneInfo: /usr/share/zoneinfo
replication:
replSetName: rs01
also i tried using replica set with key file authentication
and using SCRAM to Authenticate Clients
additional configuration part:
security:
authorization: enabled
keyFile: /opt/mongokey/key.txt
I first created the main administrator with roles:
{ role: "root", db: "admin" }
and after two users for the rocketchat base and oplog with roles
> for oplog:
{ role: "read", db: "local"},
{ role: "clusterMonitor", db: "admin" }
> for rocketchat
{ role: "readWrite", db: "rchatdb" },
After I started the mongodb server and executed Initiates a replica set
mongo --eval “printjson(rs.initiate())” --authenticationDatabase “admin” -u “mainadmin” -p
or tried a little different
rs.initiate( { _id : “rs01”, members: [ { _id: 0, host: “192.168.10.70:27017” } ] })
rs.conf() and rs.status() - the output shows that everything is ok
2. RocketChat Server
I tried to build rocketchat both manually and run through docker
Based on the rocketchat documentation, I connected mongodb through environment variables
- simple connect:
Environment=MONGO_URL=mongodb://192.168.10.70:27017/rchatdb?replicaSet=rs01
Environment=MONGO_OPLOG_URL=mongodb://192.168.10.70:27017/local?replicaSet=rs01
- connection with using authentication
Environment=MONGO_URL=mongodb://rocketchatuser:password@192.168.10.70:27017/rchatdb?authSource=admin&replicaSet=rs01
Environment=MONGO_OPLOG_URL=mongodb://oploguser:password@192.168.10.70:27017/local?authSource=admin&replicaSet=rs01
i tried also trying setting the INSTANCE_IP
docker (simple connect):
docker run -dt --name rocketchat-node1 -p 3001:3001
-e “PORT=3001”
-e “ROOT_URL=https://example.com”
-e “MONGO_URL=mongodb://192.168.10.70:27017/rchatdb?replicaSet=rs01”
-e “MONGO_OPLOG_URL=mongodb://192.168.10.70:27017/local?replicaSet=rs01”
-e “INSTANCE_IP=192.168.10.8”
rocketchat/rocket.chat:5.2.0
In general, with one instance, it works without errors, as soon as I add 2 second instance and more connections, an error appears
As an alternative and experiment, I tried using Percona Server for MongoDB, but I come back to this error
3. NGINX
my config nginx is based on these articles:
maybe I’m doing something wrong, please help find me the solution to this problem, thanks
- Version of Rocket.Chat Server: 5.2.0
- Operating System: Ubuntu 20.04/Debian 11
- Deployment Method: Manual Install and Docker
- Number of Running Instances: 2-4
- DB Replicaset Oplog: Yes
- NodeJS Version: 14.19.3
- MongoDB Version: 4.4.17/5.0.13
- Proxy: NIGNX
- Firewalls involved: no
last logs:
| SERVER RUNNING |
| Rocket.Chat Version: 5.2.0 |
| NodeJS Version: 14.19.3 - x64 |
| MongoDB Version: 4.4.17 |
| Platform: linux |
| Process Port: 3001 |
| Site URL: example_net |
| ReplicaSet OpLog: Enabled |
| Commit Hash: 08f03cc9d8 |
| Commit Branch: HEAD |
{“level”:40,“time”:“2022-10-27T15:53:24.715Z”,“pid”:1,“hostname”:“98cf544766d4”,“name”:“StreamBroadcast”,“msg”:“You are operating multiple instances… some features will not behave as designed.”}
{“level”:50,“time”:“2022-10-27T16:02:43.066Z”,“pid”:1,“hostname”:“98cf544766d4”,“name”:“System”,“msg”:“Exception while invoking method autoTranslate.getSupportedLanguages ‘Auto-Translate is disabled [error-autotranslate-disabled]’”}
{“level”:40,“time”:“2022-10-27T16:03:33.981Z”,“pid”:1,“hostname”:“98cf544766d4”,“name”:“StreamBroadcast”,“msg”:“You are operating multiple instances… some features will not behave as designed.”}
{“level”:50,“time”:“2022-10-27T16:05:34.027Z”,“pid”:1,“hostname”:“98cf544766d4”,“name”:“System”,“msg”:“Exception while invoking method autoTranslate.getSupportedLanguages ‘Auto-Translate is disabled [error-autotranslate-disabled]’”}
{“level”:50,“time”:“2022-10-27T16:50:19.641Z”,“pid”:1,“hostname”:“98cf544766d4”,“name”:“System”,“msg”:“Exception while invoking method autoTranslate.getSupportedLanguages ‘Auto-Translate is disabled [error-autotranslate-disabled]’”}
