Server not running after run in docker
I successfully install and run the rocket.chat in docker. However, the rocket.chat server is not running.
  • Operating System: MACOS
  • Deployment Method: docker
  • NodeJS Version: v14.21.4
  • MongoDB Version: 4.4
  • Firewalls involved:no
Below is the RocketChat log in docker
2023-12-07 14:23:31 (node:1) NOTE: We are formalizing our plans to enter AWS SDK for JavaScript (v2) into maintenance mode in 2023.
2023-12-07 14:23:31
2023-12-07 14:23:31 Please migrate your code to use AWS SDK for JavaScript (v3).
2023-12-07 14:23:31 For more information, check the migration guide at Migrate from version 2.x to 3.x of the AWS SDK for JavaScript - AWS SDK for JavaScript
2023-12-07 14:23:31 (Use node --trace-warnings ... to show where the warning was created)
2023-12-07 14:23:31 MessageType.render is deprecated. Use MessageType.message instead. livechat_webrtc_video_call
2023-12-07 14:23:31 LocalStore: store created at
2023-12-07 14:23:32 {“level”:40,“time”:“2023-12-07T06:23:32.132Z”,“pid”:1,“hostname”:“be3f9f68b36e”,“name”:“VoIPService”,“msg”:“Voip is not enabled. Cant start the service”}
thats it and it no more log afterward.
Mac can take a LONG time to start up. Especially if on apple silicon
how LONG it will take? Because after the service started and put it there more than half an hour still like that.
