Hi. I am updating a bunch of Rocketchat instances that I am maintaining, but I run into issue in each one of them. When I update the mongo and rocketchat versions, the first time I run docker compose up -d the containers boot, Rocketchat successfully connects to mongo and the service is working fine.
However, after restarting the containers with docker compose down then docker compose up -d the rocketchat container starts but doesn’t boot up rocketchat. Below is the log from docker logs command indicating where it hangs. Please note that on the first boot (when it works fine), it still shows the same errors, but after that, it continues with establishing connections and running, but after docker restart it just hangs at this step.
docker logs rocketchat-1
strict mode: missing type "object" for keyword "additionalProperties" at "#" (strictTypes)
strict mode: missing type "object" for keyword "properties" at "#" (strictTypes)
strict mode: use allowUnionTypes to allow union type keyword at "#/properties/value" (strictTypes)
(node:1) NOTE: We are formalizing our plans to enter AWS SDK for JavaScript (v2) into maintenance mode in 2023.
Please migrate your code to use AWS SDK for JavaScript (v3).
For more information, check the migration guide at https://a.co/7PzMCcy
(Use `node --trace-warnings ...` to show where the warning was created)
LocalStore: store created at
MessageType.render is deprecated. Use MessageType.message instead. livechat_webrtc_video_call
{"level":40,"time":"2023-11-02T11:36:44.373Z","pid":1,"hostname":"a4b7a47107e9","name":"VoIPService","msg":"Voip is not enabled. Cant start the service"}
- Version of Rocket.Chat Server: 6.3.10
- Operating System: Ubuntu-22
- Deployment Method: docker
- DB Replicaset Oplog: ?
- NodeJS Version: ?
- MongoDB Version: 5.0
- Firewalls involved: no
