Hi reetp, solved the ulimits but now dont know how generate the cert.
Here the snap logs caddy:
2026-05-11T15:38:00+02:00 rocketchat-server.rocketchat-caddy[1414]: {“level”:“info”,“ts”:1778506680.2406948,“logger”:“tls”,“msg”:“served key authentication certificate”,“server_name”:“rocket.myserver.it”,“challenge”:“tls-alpn-01”,“remote”:“13.50.14.197:58348”,“distributed”:false}
2026-05-11T15:38:00+02:00 rocketchat-server.rocketchat-caddy[1414]: {“level”:“info”,“ts”:1778506680.5527573,“logger”:“tls”,“msg”:“served key authentication certificate”,“server_name”:“rocket.myserver.it”,“challenge”:“tls-alpn-01”,“remote”:“3.137.156.132:52668”,“distributed”:false}
2026-05-11T15:38:00+02:00 rocketchat-server.rocketchat-caddy[1414]: {“level”:“info”,“ts”:1778506680.6158233,“logger”:“tls”,“msg”:“served key authentication certificate”,“server_name”:“rocket.myserver.it”,“challenge”:“tls-alpn-01”,“remote”:“54.179.213.147:62418”,“distributed”:false}
2026-05-11T15:38:00+02:00 rocketchat-server.rocketchat-caddy[1414]: {“level”:“info”,“ts”:1778506680.6475992,“logger”:“tls”,“msg”:“served key authentication certificate”,“server_name”:“rocket.myserver.it”,“challenge”:“tls-alpn-01”,“remote”:“54.200.80.116:27528”,“distributed”:false}
2026-05-11T15:38:01+02:00 rocketchat-server.rocketchat-caddy[1414]: {“level”:“error”,“ts”:1778506681.4214776,“logger”:“tls.issuance.acme.acme_client”,“msg”:“challenge failed”,“identifier”:“rocket.myserver.it”,“challenge_type”:“tls-alpn-01”,“status_code”:403,“problem_type”:“urn:ietf:params:acme:error:caa”,“error”:“While processing CAA for rocket.myserver.it: CAA record for myserver.it prevents issuance”}
2026-05-11T15:38:01+02:00 rocketchat-server.rocketchat-caddy[1414]: {“level”:“error”,“ts”:1778506681.4215336,“logger”:“tls.issuance.acme.acme_client”,“msg”:“validating authorization”,“identifier”:“rocket.myserver.it”,“error”:“[rocket.myserver.it] authorization failed: HTTP 403 urn:ietf:params:acme:error:caa - While processing CAA for rocket.myserver.it: CAA record for myserver.it prevents issuance”,“order”:“https://acme-staging-v02.api.letsencrypt.org/acme/order/291274553/37715054123",“attempt”:1,"max_attempts”:3}
2026-05-11T15:38:01+02:00 rocketchat-server.rocketchat-caddy[1414]: {“level”:“error”,“ts”:1778506681.4215693,“logger”:“tls.obtain”,“msg”:“could not get certificate from issuer”,“identifier”:“rocket.myserver.it”,“issuer”:“acme-v02.api.letsencrypt.org-directory”,“error”:“HTTP 403 urn:ietf:params:acme:error:caa - While processing CAA for rocket.myserver.it: CAA record for myserver.it prevents issuance”}
2026-05-11T15:38:01+02:00 rocketchat-server.rocketchat-caddy[1414]: {“level”:“warn”,“ts”:1778506681.4217012,“logger”:“tls.issuance.zerossl”,“msg”:“missing email address for ZeroSSL; it is strongly recommended to set one for next time”}
2026-05-11T15:38:01+02:00 rocketchat-server.rocketchat-caddy[1414]: {“level”:“error”,“ts”:1778506681.5729482,“logger”:“tls.obtain”,“msg”:“could not get certificate from issuer”,“identifier”:“rocket.myserver.it”,“issuer”:“acme.zerossl.com-v2-DV90”,“error”:“account pre-registration callback: failed getting EAB credentials: HTTP 422: caddy_legacy_user_removed (code 2977)”}
2026-05-11T15:38:01+02:00 rocketchat-server.rocketchat-caddy[1414]: {“level”:“error”,“ts”:1778506681.5730047,“logger”:“tls.obtain”,“msg”:“will retry”,“error”:“[rocket.myserver.it] Obtain: account pre-registration callback: failed getting EAB credentials: HTTP 422: caddy_legacy_user_removed (code 2977)”,“attempt”:2,“retrying_in”:120,“elapsed”:68.679704411,“max_duration”:2592000}
root@Linux127:/home/administrator#
