How to renew caddy certificate
Version of Rocket.Chat Server: 2.4.11
Operating System: Linux mint 19.3 Trica 64-bit
Deployment Method: Quick installation
Number of Running Instances:
DB Replicaset Oplog:
NodeJS Version: v8.17.0
MongoDB Version: 3.6.14
Proxy: NO
Firewalls involved: NO
Caddy Status
● snap.rocketchat-server.rocketchat-caddy.service - Service for snap application rocketchat-server.rocketchat-caddy
Loaded: loaded (/etc/systemd/system/snap.rocketchat-server.rocketchat-caddy.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2020-06-12 12:22:57 EEST; 3 days ago
Main PID: 1071 (caddy)
Tasks: 20 (limit: 4915)
CGroup: /system.slice/snap.rocketchat-server.rocketchat-caddy.service
└─1071 caddy -conf=/var/snap/rocketchat-server/1427/Caddyfile
июн 15 12:24:16 chat-H81M-S1 rocketchat-server.rocketchat-caddy[1071]: 2020/06/15 12:24:16 [INFO] [chat.eliz.zp.ua] acme: Trying renewal with -1531 hours remaining
июн 15 12:24:16 chat-H81M-S1 rocketchat-server.rocketchat-caddy[1071]: 2020/06/15 12:24:16 [INFO] [chat.eliz.zp.ua] acme: Obtaining bundled SAN certificate
июн 15 12:24:17 chat-H81M-S1 rocketchat-server.rocketchat-caddy[1071]: 2020/06/15 12:24:17 [INFO] [chat.eliz.zp.ua] AuthURL: https://acme-v02.api.letsencrypt.org/acme/authz-v3/5251334886
июн 15 12:24:17 chat-H81M-S1 rocketchat-server.rocketchat-caddy[1071]: 2020/06/15 12:24:17 [INFO] [chat.eliz.zp.ua] acme: Could not find solver for: tls-alpn-01
июн 15 12:24:17 chat-H81M-S1 rocketchat-server.rocketchat-caddy[1071]: 2020/06/15 12:24:17 [INFO] [chat.eliz.zp.ua] acme: use http-01 solver
июн 15 12:24:17 chat-H81M-S1 rocketchat-server.rocketchat-caddy[1071]: 2020/06/15 12:24:17 [INFO] [chat.eliz.zp.ua] acme: Trying to solve HTTP-01
июн 15 12:24:36 chat-H81M-S1 rocketchat-server.rocketchat-caddy[1071]: 2020/06/15 12:24:36 [INFO] Deactivating auth: https://acme-v02.api.letsencrypt.org/acme/authz-v3/5251334886
июн 15 12:24:36 chat-H81M-S1 rocketchat-server.rocketchat-caddy[1071]: 2020/06/15 12:24:36 [INFO] Unable to deactivate the authorization: https://acme-v02.api.letsencrypt.org/acme/authz-v3/5251334886
июн 15 12:24:37 chat-H81M-S1 rocketchat-server.rocketchat-caddy[1071]: 2020/06/15 12:24:37 [INFO] [chat.eliz.zp.ua] acme: Trying renewal with -1531 hours remaining
июн 15 12:24:37 chat-H81M-S1 rocketchat-server.rocketchat-caddy[1071]: 2020/06/15 12:24:37 [INFO] [chat.eliz.zp.ua] acme: Obtaining bundled SAN certificate
Sorry if I ask obvious things, but I don’t understand how to solve this problem.
Our company has a configured Rocket Chat server. And caddy as a server encrypting external connections. For reasons beyond my control, the computer on which Rocket Chat and Cuddy was installed was turned off for 2 months, the certificate update time has passed and now an outdated SSL certificate has been installed.
How can it be updated now? Is there any command for this? Or do you have to wait until it updates itself? Thank you in advance.
Did you solve your problem ?
I have suddendly the same one … .but my RC server is ON since many months.
But yesterday, impossible to renew caddy certificate … and with snap, not easy to find where they are, where is the config file.
I prefer put my own certificate but nowhere i find how configure
1st edit
SOLVE !
I just copy my own certificate (CRT et KEY files) in my current RC directory (/var/snap/rocketchat-server/XXXX)
and modifiy the Caddyfile :
https://my.site.fr
proxy / localhost:3000 {
websocket
transparent
tls certif.crt certif.key
After restart RC and Caddy service, all works fine
2nd edit
all ? no … the android appli ahve a java error. not via the web navigator, only mobile appli (android test, no appeule test, i don’t have enough money)
Yes, we managed to solve this problem. The problem, as I understood it, was that port 80 was not open from the outside to the rocket chat. Ie it is necessary to open 443 and 80 TCP ports from the outside.
All the port (80 and 443) are open outside but the letsencrypt certificate initiate with caddy doesn’t renew.
After use my own certs, RC works on navigator, not on Android app (java arror)
This force caddy renew the certificates:
snap stop rocketchat-server.rocketchat-caddy
# in "/root/snap/rocketchat-server/current" remover a pasta .caddy que contém os certificados
sudo su
cd /root/snap/rocketchat-server/current
mv .caddy .caddy.bak
# Ao statar o serviço o Caddy gerará nova pasta com novos certificados
snap start rocketchat-server.rocketchat-caddy
