Rocket.chat's android app has no notification sound
The service version is 7.7.1.
The Android app version is 4.62.0.83978, but the service version displayed in the app is 7.7.0.
The problem is that all notifications in the Android app are silent. How can I troubleshoot this issue?
4.63 is out
Upgrade. There are security fixes.
Always. For “security” apparently.
Tell us about your server. Particularly firewalls, reverse proxy, https certificates, and websockets.
Information required
I’m not an expert. I deployed it using Docker on Synology. I forwarded port 39000 through the firewall. The certificate is Let’s Encrypt. The websocket configuration is Upgrade=$http_upgrade
Connection=$connection_upgrade
If you run a server you have volunteered yourself to be an admin……
So go back and fill in the details we have asked for and tell us what your rocketchat logs say. We really can’t help without that.
We are not sat in front of your box. I have never used a Synology box before so no idea.
It is not a “recommended” solution so answers may be hard to find.
See my previous gist for testing websockets as well.
