The first error only happens with MS Edge on Android. Chrome, Samsung Internet, and other mobile browsers work fine, and all IOS mobile devices work fine as well.
This error happens after you connect to the site and are getting the three dots displayed:
mongo_utils.js:11 Uncaught Error: The core-js npm package could not be found in your node_modules
directory. Please run the following command to install it:
meteor npm install --save core-js
at t (mongo_utils.js:11:1)
at g (url_common.js:81:1)
at d.r (url_common.js:81:1)
at er.require (verifyErrors.js:34:1)
at Object.t [as require] (url_common.js:81:1)
at a (load-js-image.js:69:1)
at load-js-image.js:106:1
at t (load-js-image.js:109:1)
at Object.t [as queue] (load-js-image.js:42:1)
at mongo_utils.js:11:1
t @ mongo_utils.js:11
g @ url_common.js:81
r @ url_common.js:81
er.require @ verifyErrors.js:34
t @ url_common.js:81
a @ load-js-image.js:69
(anonymous) @ load-js-image.js:106
t @ load-js-image.js:109
t @ load-js-image.js:42
(anonymous) @ mongo_utils.js:11
The second error only occurs on Android Devices when using the Rocket.Chat mobile app installed. It’s the “Invalid Workspace URL” error. The test Open Rocket.Chat appears to work fine, but our implementation does not.
Any insight would be greatly appreciated.
Please let me know if you need any more information on the environment or need any more detail on anything.
Hi, were you able to solve this issue? I’m experiencing the same problem. I’m running Rocket.Chat 7.2.1 with MongoDB 6.0 on Ubuntu 24 LTS, installed manually. Unfortunately, the latest version of the Android app doesn’t work and shows ‘Invalid Workspace URL,’ while it works fine on iOS.
I have SSL properly configured using Nginx as a reverse proxy, following the official Rocket.Chat documentation: Configuring SSL Reverse Proxy.
Additionally, the connection works fine on iOS, but the Android app still shows the ‘Invalid Workspace URL’ error. I have also tested connecting to open.rocket.chat, and that works fine.
Thank you for the response and suggestions. I’ve tested various configurations, but unfortunately, without success. I also tested on a virtual Android device, and the issue persists. I’ve also created a fresh test instance of Rocket.Chat, but I still can’t connect from the Android app.
Looking at the traffic in Wireshark, it seems that the app is having trouble connecting, possibly due to an issue with the TLS version. However, I don’t see any errors related to Android connections in the Nginx logs.
Additionally, I wanted to ask if port 80 needs to be forwarded? Currently, I have only port 443 forwarded to the reverse proxy on the router.
It might be the certificate that you have used. I solved this issue by combining the domain_certificate.crt, intermideate.crt, and root.crt and created a fullchain.crt and used it in nginx configuration for rocket chat.
