BigL
July 4, 2019, 7:33pm
1
Hi
I have installed grafana for my influxdb and openhab but when I opened my browser on http://192.168.178.30:3000 to login to grafana, I found the login page to rocket chat
I do not have any plans to work with rocket chat and wasn’t able to stop or uninstall it.
I have a ubuntu server running on my nas in a virtual station, when I login to rocket chat the version is 1.1.3 and was installed on Oct 27 2018.
sudo netstat -lp
tcp 0 0 0.0.0.0:3000 0.0.0.0:* LISTEN 23285/node
I’m sorry but I want to stop rocket chat running on my server. Is there a way to stop the service?
Regards Ben
try somethink like this
sudo systemctl disable rocketchat && sudo systemctl stop rocketchat
depends on your OS
BigL
July 6, 2019, 6:40am
3
sudo systemctl disable rocketchat returns
Failed to disable unit: Unit file rocketchat.service does not exist.
sudo systemctl stop rocketchat returns
Failed to stop rocketchat.service: Unit rocketchat.service not loaded.
How could that be that no service ist running, but Rocket Chat is there and I can login in to it?
sudo /etc/init.d/rocketchat stop
BigL
July 8, 2019, 8:16am
5
that doesn’t work:
sudo: /etc/init.d/rocketchat: command not found
Can I provide you with more information, please ask if there is something I can do ? I greatly appreciate your help. Thanks
try to at first kill RC…
This shows process number>
#ps aux |grep rocket
and then kill proces
#kill -9 PROCESNR
you can always disable RC site in apache
a2dissite rocketchat
/etc/init.d/apache2 restart
BigL
July 8, 2019, 12:57pm
8
doesn’t work
ps aux |grep rocket
root 828 0.0 0.0 4504 0 ? Ss Jul03 0:00 /bin/sh /snap/rocketchat-server/1384/bin/startmongo
root 1057 1.2 2.6 1502392 26924 ? Sl Jul03 86:32 mongod --bind_ip 127.0.0.1 --pidfilepath /var/snap/rocketchat-server/common/mongod.pid --smallfiles --journal --dbpath=/var/snap/rocketchat-server/common --replSet rs0
root 5518 0.6 0.0 18100 228 ? Ss 12:45 0:00 /bin/bash /snap/rocketchat-server/1384/bin/startRocketChat
root 5607 37.3 42.3 1712844 427540 ? Dl 12:45 0:47 node /snap/rocketchat-server/1384/main.js
root 5864 0.0 0.0 13136 944 pts/0 S+ 12:47 0:00 grep --color=auto rocket
kill -9 -5518
(PROCESSID for startRocketChat - stops the service on port 3000)
a2dissite rocketchat /etc/init.d/apache2 restart
Command ‘a2dissite’ not found, but can be installed with:
apt install apache2
rocketchat restarts after a minute
eh,
it looks like that u have snap ?
I have no idea how it works with snap, but google something how to stop service +snap
maybe this :
sudo service snap.rocketchat-server.rocketchat-server stop
BigL
July 8, 2019, 1:48pm
10
Yes this works
As I didn’t know what snap is, this is a good start to get more familiar with snap apps.
Many thanks
cheers
