Steps to reproduce:
I am trying to connect to channel via websocket from Flutter application
Tried to use this Map to create login object:
Map msg = {
"msg": "method",
"method": "login",
"id": Random().nextInt(Constants.int32MaxValue),
"params": [
{"resume": authToken}
webSocketChannel.sink.add(jsonEncode(msg));
Expected behavior:
As described in the API Docs A successful call will return the same message as a successful login (which it is).
Actual behavior:
Connection happens as expected, while login is unsuccessful
Server Setup Information:
- Version of Rocket.Chat Server: 3.11.1
- Operating System: Ubuntu
- NodeJS Version: v12.20.2
- MongoDB Version: 4.0.23
Relevant logs:
[log] ws event occurred: {“msg”:“connected”,“session”:“XXXXXX”}
I/flutter (11448): Notification{msg: UNKNOWN, collection: null, serverId: null, subs: null, methods: null, id: null, fields: null, result: null}
[log] ws event occurred: {“msg”:“error”,“reason”:“Malformed method invocation”,“offendingMessage”:{“msg”:“method”,“method”:“login”,“id”:4527266,“params”:[{“resume”:“XXXXXX”}]}}
