Migrate from manual install to docker
I’m looking for advice and possibly a “how to”. We’re using a manual install of RocketChat on Debian Linux. I would like to consider migrating to Docker. How difficult is that likely to be? I have some experience with Docker.
It shouldn’t be difficult.
consider you will use same versions on both installs.
basically:
  • get DB dump and uploads (if they are in filesystem instead of GridFS) from current install
  • run a docker instance on your machine
  • restore data to the mongo docker instance and copy the uploads to the uploads file
  • run it
If you need upgrading to latest version, do it before or after this migration.
check this for some more about restoring mongo inside docker:
Thanks. I’ll look into this and hopefully be able to work on it soon.
It sounds like a straightforward process.
