Upgrading RC and Mongo DB in docker
I’m trying to update rocketchat and mongodb but this was installed so long ago there is no docker composer plugin nor does it have a .yml & .env file. What would be the best method to update both rocket chat and mongodb?
  • Version of Rocket.Chat Server: 1.0.3
  • Operating System: CentOS_7
  • Deployment Method: DOCKER
  • Number of Running Instances: 2
  • NodeJS Version: 8.11.4
  • MongoDB Version: 4.0.9
  • Proxy: nginx
  • Firewalls involved:N/A
NA
if I was in your position, I would use docker inspect on the two containers, to help me rebuild a docker-compose.yml and .env file.
Once I have that I would make a snapshot and then test docker-compose down and docker-compose up to check that it is working. (don’t use ‘latest’ in any image tags)
Next I followed this script to upgrade my mongo DB version. Maybe it helps you:
#!/usr/bin/env bash
read -p "Are you sure? (y/n)" -n 1 -r
echo    # (optional) move to a new line
if [[ ! $REPLY =~ ^[Yy]$ ]]
then
    [[ "$0" = "$BASH_SOURCE" ]] && exit 1 || return 1 # handle exits from shell or function but don't exit interactive shell
fi
sudo docker rm -f rocketchat-mongo-upgrade
set -e
sudo docker pull mongo:4.2.17
sudo docker pull mongo:4.4.9
sudo docker pull mongo:5.0.3
sudo docker-compose stop
sudo docker start rocketchat-mongo
until sudo docker exec rocketchat-mongo mongo
do
    echo "Waiting for Mongo to start..."
    sleep 1
done
sudo docker exec -u0 rocketchat-mongo rm -r -f /dump
sudo docker exec -u0 rocketchat-mongo mkdir /dump
echo "Starting dump.."
sudo docker exec -u0 rocketchat-mongo mongodump --out=/dump
sudo docker exec -u0 rocketchat-mongo tar -czf /dump.tgz /dump
sudo docker cp rocketchat-mongo:/dump.tgz dump.tgz
echo "Backup complete. Stopping old Mongo"
sudo docker stop rocketchat-mongo
sudo rm -r -f data  #data is where my mongo database bind mount is
echo "Starting new Mongo.."
sudo docker run -d \
  --name rocketchat-mongo-upgrade \
  -v $(pwd)/data:/data/db \
 mongo:4.0.25 \
 mongod --oplogSize 128 --replSet rs0 --storageEngine=wiredTiger
sudo docker cp dump.tgz rocketchat-mongo-upgrade:/dump.tgz
sudo docker exec rocketchat-mongo-upgrade tar -xzf /dump.tgz
until sudo docker exec rocketchat-mongo-upgrade mongo
do
    sleep 1
done
echo "Initializing Mongo..."
sudo docker exec rocketchat-mongo-upgrade mongo 127.0.0.1/rocketchat --eval "rs.initiate({_id: 'rs0', members: [ { _id: 0, host: 'localhost:27017' } ]})"
echo "Restoring database.."
sudo docker exec -u0 rocketchat-mongo-upgrade mongorestore /dump
echo "Cleaning up.."
sudo docker stop rocketchat-mongo-upgrade
sudo docker rm -v rocketchat-mongo-upgrade
sudo rm dump.tgz
echo
echo "Upgrading mongo verstion to 4.2.17.."
 mongo:4.2.17 \
do
    sleep 1
done
sudo docker exec rocketchat-mongo-upgrade mongo 127.0.0.1/rocketchat --eval "db.adminCommand( { setFeatureCompatibilityVersion: \"4.2\" } )"
sudo docker logs rocketchat-mongo-upgrade
echo
echo "Upgrading mongo verstion to 4.4.9.."
 mongo:4.4.9 \
do
   sleep 1
done
sudo docker exec rocketchat-mongo-upgrade mongo 127.0.0.1/rocketchat --eval "db.adminCommand( { setFeatureCompatibilityVersion: \"4.4\" } )"
echo
echo "Cleaning up container images."
sudo docker image prune -a
Hi @stefan.badenhorst !
Thanks for sharing your work with us! We really appreciate it.
At the end of the day, migrating Rocket.Chat mongo versions will usually by a dump and restore process.
This script makes it easy, as it will dump and restore.
Thanks for sharing :slight_smile:
