On your Ubuntu with RocketChat installed via Snap:
- Stop your RC
sudo service snap.rocketchat-server.rocketchat-server stop
- Make sure your mongo is still running
sudo service snap.rocketchat-server.rocketchat-mongo status | grep Active
Active: active (running) (…)
- Make backup of your RC database
sudo snap run rocketchat-server.backupdb
- Your should receive:
[+] A backup of your data can be found at /var/snap/rocketchat-server/common/backups/rocketchat_backup_XXXX.tgz
- Go to folder with backup and send it to your CentOS via SSH
scp backup.tgz user@CentOsIPaddress:/home/user
On CentOs with manual installed RocketChat:
- Stop RocketChat
service rocketchat stop
- Drop (delete) rocketchat database
mongo
show dbs
use rocketchat
db.dropDatabase()
You should receive
{ “dropped” : “rocketchat”, “ok” : 1 }
- Untar your backup
tar zxvf backup.tgz
- Restore backup
mongorestore --db rocketchat var/snap/rocketchat-server/XXXX/dump/parties/
- Reboot your OS
reboot
Check your RC, it should be fine ![]()
