How to disable 2fa?
I just updated to 4.4.2 and am getting prompted for 2fa on my android app. How do I disable 2fa for all users?
Also, I am not getting the email that contains the code for the 2fa. I do not have an email server set up so is that email supposed to be coming from the rocket.chat servers?
UPDATE: OK, I am logged into my user (an admin) on my computer. I found the “Security” section for my account. And I see that the option to “Disable two-factor authentication via Email” is available. But… it appears I need to send an email for that. Like I said I don’t have an email server set up. How do I disable this w/o an email?
UPDATE: I enabled TOTP and was able to log in on my phone via that. But I don’t want any 2FA. Its just a family server. However, now I am concerned about disabling it because it could be enabled again in an update in the future (it appears to have happened with this update) and I guess I was lucky I was able to log in w/ my computer when my phone required the 2FA.
Please, try going into:
ADMIN > ACCOUNT > Two Factor Authentication > Disable
this should disable 2fa for all users.
for me its not working and nobody can login, same issue os OP including me as admin.
How to remove this permanently inside config?
