Hello Everyone,
I’m relatively new to Rocket.Chat and have been exploring its capabilities. I’m currently working on a project where I’d like to set up Rocket. I could use some direction to make sure I’m headed in the right direction when it comes to chat in a multi-tenant setup.
The situation I’m working with is as follows:
Goal: I’m configuring a single instance of Rocket.Chat to support several organizations, each of which needs its own separate channels, users, and permissions.
Requirements: To protect privacy, every organization should have a unique user database, branded login page, and access controls.
Infrastructure: Ubuntu 22.04, Docker, and MongoDB will be installed on a VPS with enough resources to host the instance.
I’ve read the forums and documentation, but I still have a few questions:
Isolate Organizations: Is total tenant isolation supported natively by Rocket.Chat? If not, is there a suggested workaround, or would spinning up distinct instances for every organization be the only option? ![]()
Custom Branding: Within a single Rocket.Chat instance, is it possible to set up distinct login pages or themes for every organization? ![]()
User Management: Is it possible to automate role assignments and user onboarding for various tenants using extensions or suggested tools? ![]()
Performance Advice: What are the best ways to maximize performance in a multi-tenant setting where each tenant may have more than 1,000 users? ![]()
Any tips, settings, or plugins you could recommend to improve the effectiveness and scalability of this setup would be greatly appreciated.
Thanks in advance for your help and support.
