HA docker-compose stack & todo's
Hey ya’all,
here is my docker-compose wich creates a mongo-replica set of 3 containers and 2 rocketchat containers on port 3000 & 3001.
atm this is only for testing scenarios but maybe in near future it can be used in a production environment too.
version: ‘2’
services:
rocketchat:
container_name: rc1
restart: unless-stopped
volumes:
- ./uploads:/app/uploads
- PORT=3000
- ROOT_URL=http://localhost:3000
- MONGO_URL=mongodb://mongo1:27017,mongo2:27017,mongo3:27017/rocketchat?replicaSet=rs0
- MONGO_OPLOG_URL=mongodb://mongo1:27017,mongo2:27017,mongo3:27017/local?replicaSet=rs0
- MAIL_URL=smtp://smtp.email
depends_on:
- mongo1
- mongo2
- mongo3
ports:
- 3000:3000
rocketchat2:
container_name: rc2
volumes:
- PORT=3001
- ROOT_URL=http://localhost:3001
depends_on:
- mongo1
- mongo2
- mongo3
ports:
- 3001:3001
mongo1:
container_name: db1
image: mongo:3.2
command: mongod --smallfiles --oplogSize 128 --replSet rs0
volumes:
- ./data/db1:/data/db1
mongo2:
container_name: db2
image: mongo:3.2
volumes:
- ./data/db2:/data/db2
mongo3:
container_name: db3
image: mongo:3.2
volumes:
- ./data/db3:/data/db3
mongo-init-replica:
image: mongo:3.2
command: ‘mongo mongo1/rocketchat --eval “rs.initiate({ _id: ‘‘rs0’’, members: [ { _id: 0, host: ‘‘mongo1:27017’’ },{ _id: 1, host: ‘‘mongo2:27017’’ },{ _id: 2, host: ‘‘mongo3:27017’’ } ]})”’
depends_on:
- mongo1
- mongo2
- mongo3
maybe someone’s here who will help me with an nginx-part who will be responsible for reverse-proxy’ing. so he should listen on 80 and redirect all traffic to 443.
for this it’ll be great if we can implement letsencrypt.
I’d be happy if there’s someone here who wants to help out. :slight_smile:
I moved this over to community creations since this is more about sharing.
Thanks for sharing btw :slight_smile:
update to newer version with working hubot.
if you have your cert you only have to put it into a local “cert” folder wich is mapped into nginx container:
version: ‘2’
services:
nginx-proxy:
image: jwilder/nginx-proxy
container_name: nginx-proxy
ports:
- ‘80:80’
- ‘443:443’
volumes:
- ‘/etc/nginx/vhost.d’
- ‘/usr/share/nginx/html’
- ‘./certs:/etc/nginx/certs:ro’
- ‘/var/run/docker.sock:/tmp/docker.sock:ro’
db1:
container_name: db1
image: mongo:3.2
volumes:
db2:
container_name: db2
image: mongo:3.2
volumes:
db3:
container_name: db3
image: mongo:3.2
volumes:
mongo-init-replica:
image: mongo:3.2
command: ‘mongo db1/rocketchat --eval “rs.initiate({ _id: ‘‘rs0’’, members: [ { _id: 0, host: ‘‘db1:27017’’ },{ _id: 1, host: ‘‘db2:27017’’ },{ _id: 2, host: ‘‘db3:27017’’ } ]})”’
depends_on:
- db1
- db2
- db3
rc1:
container_name: rc1
volumes:
- PORT=3000
- ROOT_URL=http://127.0.0.1:3000
- MONGO_URL=mongodb://db1:27017,db2:27017,db3:27017/rocketchat?replicaSet=rs0
- MONGO_OPLOG_URL=mongodb://db1:27017,db2:27017,db3:27017/local?replicaSet=rs0
- VIRTUAL_HOST=rctest.yourdomain.co
depends_on:
- db1
- db2
- db3
- mongo-init-replica
rc2:
container_name: rc2
volumes:
- PORT=3000
depends_on:
- db1
- db2
- db3
hubot:
container_name: hubot
image: rocketchat/hubot-rocketchat:latest
- ROCKETCHAT_URL=rc1:3000
- LISTEN_ON_ALL_PUBLIC=true
- ROCKETCHAT_USER=tutor
- ROCKETCHAT_PASSWORD=tutor
- BOT_NAME=tutor
- EXTERNAL_SCRIPTS=hubot-help,hubot-seen,hubot-links,hubot-diagnostics,hubot-google,hubot-reddit,hubot-bofh,hubot-bookmark,hubot-shipit,hubot-maps
networks:
default:
external:
ATM i’m searching for a cool & valid backup strategy for all this.
maybe someone has a cool idea.
very important for me right now is to backing up the mongo db replica-set.
Usually people just do mongodump with some clever way of scheduling it
mmh i see.
for testing purposes i quck & dirty wrote this one:
d=$(date +%Y-%m-%d)
docker-compose exec db1 mongodump --oplog
docker cp db1:/dump /opt/container/rocketchat/mongodump
docker exec db1 rm -rf /dump
mkdir -p /opt/container/rocketchat/tmp
tar -zcvf /opt/container/rocketchat/tmp/“$d”_mongodump_rocketchat.tar.gz /opt/container/rocketchat/mongodump/rocketchat
upload to s3
/usr/local/bin/aws s3 cp /opt/container/rocketchat/tmp/*.tar.gz s3://mongobucket/“$d”_mongodump_rocketchat.tar.gz
rm -rf /opt/container/rocketchat/tmp
rm -rf /opt/container/rocketchat/mongodump
crontab -l
0 3 * * * /opt/container/rocketchat/moo > /opt/container/rocketchat/output
i’m sure it’s not the best but right now it does the trick.
for downloading the latest dump from s3 back to local i wrote this:
BUCKET="the_mongo_backup_bucket"
FILE=`aws s3 ls $BUCKET --recursive | sort | tail -n 1 | awk '{print $4}'`
aws s3 cp s3://$BUCKET/$FILE .
next will be rolling back the latest backup into mongo replica set.
will write about that later.
cheers!
to bad that there’s an issue which is relatet to this construct i’m building here:
you cant use s3 to storage your files - because of this issue!
Sticky sessions is one way some people work around this.
How do you implement stickiness in this context - and how to do do thin on open.rocket.chat?
That’s the thing. We use object store and no stickiness. Definitely multi-instance. No issues.
Is there any documentation out there about this?
tryed to get it working with an jwilder-fork but had no luck yet.
i’m always getting the error no host in upstream using tpcwang/nginx-proxy:latest with this docker-compose.yml:
version: '3'
services:
  nginx-proxy:
    image: tpcwang/nginx-proxy:latest
    ports:
      - '80:80'
      - '443:443'
    volumes:
      - '/etc/nginx/vhost.d'
      - '/usr/share/nginx/html'
      - './certs:/etc/nginx/certs:ro'
      - './conf.d:/etc/nginx/conf.d'
      - '/var/run/docker.sock:/tmp/docker.sock:ro'
      - USE_IP_HASH=1
    depends_on:
      - rc
  db1:
    container_name: db1
    image: mongo:3.2
    volumes:
  db2:
    container_name: db2
    image: mongo:3.2
    volumes:
  db3:
    container_name: db3
    image: mongo:3.2
    volumes:
  mongo-init-replica:
    image: mongo:3.2
    command: 'mongo db1/rocketchat --eval "rs.initiate({ _id: ''rs0'', members: [ { _id: 0, host: ''db1:27017'' },{ _id: 1, host: ''db2:27017'' },{ _id: 2, host: ''db3:27017'' } ]})"'
    depends_on:
      - db1
      - db2
      - db3
  rc:
    volumes:
      - PORT=3000
      - VIRTUAL_HOST=rctest.foo.bar
      - VIRTUAL_NETWORK=1
    depends_on:
      - db1
      - db2
      - db3
ideas?
i’ve just solved the stickyness problem with traefik!
version: '3'
services:
 traefik:
   image: traefik
   command: --web --docker --docker.domain=docker.localhost --logLevel=DEBUG
   ports:
     - "80:80"
     - "8080:8080"
     - "443:443"
   volumes:
     - /var/run/docker.sock:/var/run/docker.sock
     - /dev/null:/traefik.toml
 db1:
   container_name: db1
   image: mongo:3.2
   volumes:
 db2:
   container_name: db2
   image: mongo:3.2
   volumes:
 db3:
   container_name: db3
   image: mongo:3.2
   volumes:
 mongo-init-replica:
   image: mongo:3.2
   depends_on:
     - db1
     - db2
     - db3
 rc:
   volumes:
     - PORT=3000
   depends_on:
     - db1
     - db2
     - db3
   labels:
     - traefik.backend=echo
     - traefik.frontend.rule=Host:rctest.bla.foo
     - traefik.backend.loadbalancer.stickiness=true
todo: get tls running and for now this will be my setup for HA!
i’m not be able to get my wildcard TLS-Certificate to work within tis setup…
anyone has experience working with traefik and SSL in docker?
traefik is definitely my choice. A wildcard you should be able to include in a volume mount to bring the wildcard cert into the traefik container.
tryed many times with different errors but no lucky…
So from what I know you need to do a couple of things.
  1. Get wildcard cert and a traefik.toml inside the container
  2. Update the traefik.toml with details
  3. In traefik.toml set it up for docker so it can detect labels and such and add routes
Take a look at: https://github.com/RocketChat/Rocket.Chat/blob/develop/docker-compose.yml#L68
and https://github.com/RocketChat/Rocket.Chat/blob/develop/docker-compose.yml#L22
@aaron.ogle
Do you currently have a manual for installation in HA, from rocket.chat using the installation standard via docker compose?
I’m using this material from your colleague frdmn, I can scale the apps but I’m having problems with mongo.
For the mongo would it be like the example of the yml above? Or do you currently have another way?
if you’re looking for an HA deployment I wouldn’t probably use docker-compose. To me thats a let me do this super quick and easy. An HA deployment i’d do one of our manual installs. Now you could if you want remove mongo from the docker-compose put it external in a normal mongo cluster and then scale just Rocket.Chat with docker-compose. That might work.
But honestly even then… its HA on a single machine with docker-compose. So would be better off using kubernetes with helm chart or just a regular non-docker Rocket.Chat install. That way you have Rocket.Chat running on multiple machines and actually pull off an HA setup.
