After migration from multi-instance manual (from zip) to multi-docker scheme - got problems with RC notification and sound playing (when new message comes).
Some research:
When user1 send message to user2 connected on same NODEJS backend - evething work correct.
But when users connected to different nodejs-backend - sounds and notification does not work
How to solve problem ? Any suggestions to check config rocket\docker\mongo\oplog ?
- Version of Rocket.Chat Server: 3.12.1
- Operating System: Ubuntu 20
- Deployment Method: docker
- Number of Running Instances: 8
- DB Replicaset Oplog: Enabled rs01
- NodeJS Version: 12.18.4 - x64
- MongoDB Version: 4.0.21
- Proxy: nginx
- Firewalls involved: no
Docker-compose
version: ‘3.3’
services:
mongo:
image: mongo:4.0.21
restart: unless-stopped
volumes:
- /var/lib/mongodb:/data/db
- /mnt/backup:/mnt/backup
command: mongod --smallfiles --oplogSize 990 --replSet rs01 --storageEngine=wiredTiger
rocketchat1:
image: rocketchat/rocket.chat:3.12.1
command: >
bash -c
"for i in `seq 1 30`; do
node main.js &&
s=$$? && break || s=$$?;
sleep 5;
done; (exit $$s)"
volumes:
- /mnt/rocketchat/share:/app/uploads
- PORT=3001
- ROOT_URL=http://localhost:3001
- MONGO_URL=mongodb://mongo:27017/rocketchat?replicaSet=rs01
- MONGO_OPLOG_URL=mongodb://mongo:27017/local?replicaSet=rs01
depends_on:
- mongo
ports:
- "127.0.0.1:3001:3001"
rocketchat2:
command: >
bash -c
node main.js &&
sleep 5;
done; (exit $$s)"
volumes:
- PORT=3002
- ROOT_URL=http://localhost:3002
depends_on:
- mongo
ports:
- "127.0.0.1:3002:3002"
and etc...
NGINX:
upstream backend {
server 127.0.0.1:3001;
server 127.0.0.1:3002;
server 127.0.0.1:3003;
server 127.0.0.1:3004;
server 127.0.0.1:3005;
server 127.0.0.1:3006;
server 127.0.0.1:3007;
server 127.0.0.1:3008;
server {
listen MY_PUBLIC_IP:80 default_server;
server_name *.domain.my;
location / {
rewrite ^(.*) https://rocket.domain.my permanent;
server {
listen MY_PUBLIC_IP:443 default_server ssl;
server_name rocket.domain.my;
ssl on;
ssl_certificate /etc/nginx/ssl.crt/domain.my.crt;
ssl_certificate_key /etc/nginx/ssl.key/domain.my.key;
include ssl.conf;
location / {
proxy_pass http://backend;
proxy_http_version 1.1;
proxy_set_header X-Forward-Proto https;
proxy_redirect off;
