i use RocketChat 0.71.1 manual Install at Centos 7. Node 8.11.3 using Apache.
When i want to Install RocketChat Apps or for example use Giphy it doenst work.
“Self Signed Certificate in Certificate Chain”
I am behind a Corporate SSL inspection proxy.
Does anyone know where else i can put the certiticate path else than the Apache Config File?
I found some “Solutions” - but none of them seem to work:
Anyone know how to solve this?
What about letsencrypt.org instead of self signed?
[SOLVED]
@localguru Nah thats not the thing - the certificate is good
The Problem is the Corporate SSL inspection proxy.
I solved it by putting
process.env.NODE_TLS_REJECT_UNAUTHORIZED = “0”;
in main.js. Restart RC Service and it is working!
