We are using rocketchat docker with a mongo backend with a self signed cert. We set NODE_TLS_REJECT_UNAUTHORIZED to 0 in the docker compose and were able to connect up to version 3.1 with no issue. when i attempt to roll to version 3.8.1 I get the following errors when rocketcaht attempts to start.
Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification
MongoNetworkError: failed to connect to server [servername] on first connect [Error: self signed certificate in certificate chain
- Version of Rocket.Chat Server: 3.8.1
- Operating System: centos 7
- Deployment Method: docker
- DB Replicaset Oplog:
- NodeJS Version:
- MongoDB Version:
- Proxy:
- Firewalls involved:
