After updating to 6.10.0 browser screen is stuck on loading screen
After the update the screen is just stuck on those three dots moving from big to small in the middle of the screen. Any idea how to fix? I tried clearing cookies/cache but didn’t fix.
  • Version of Rocket.Chat Server: 6.10.0
  • Operating System: Linux CentOS 7
  • Deployment Method: docker compose
  • DB Replicaset Oplog: not sure
  • NodeJS Version: not sure
  • MongoDB Version: 5.0
  • Proxy: n/a
  • Firewalls involved: firewalld
These are my current docker logs:
[root@ELK-Stack rocketchat]# docker logs rocketchat-rocketchat-1
(node:1) NOTE: We are formalizing our plans to enter AWS SDK for JavaScript (v2) into maintenance mode in 2023.
Please migrate your code to use AWS SDK for JavaScript (v3).
For more information, check the migration guide at https://a.co/7PzMCcy
(Use `node --trace-warnings ...` to show where the warning was created)
LocalStore: store created at
{"level":40,"time":"2024-07-26T19:32:07.096Z","pid":1,"hostname":"eb89009f7138","name":"VoIPAsteriskService","msg":"Voip is not enabled. Cant start the service"}
(node:1) [MONGODB DRIVER] Warning: cursor.count is deprecated and will be removed in the next major version, please use `collection.estimatedDocumentCount` or `collection.countDocuments` instead
{"level":51,"time":"2024-07-26T19:32:07.202Z","pid":1,"hostname":"eb89009f7138","name":"Migrations","msg":"Not migrating, already at version 304"}
[2024-07-26T19:32:07.262Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/BROKER: Moleculer v0.14.31 is starting...
[2024-07-26T19:32:07.262Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/BROKER: Namespace: <not defined>
[2024-07-26T19:32:07.263Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/BROKER: Node ID: 53773364-68b1-47a8-b6fd-81376fa17113
[2024-07-26T19:32:07.265Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/REGISTRY: Strategy: RoundRobinStrategy
[2024-07-26T19:32:07.265Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/REGISTRY: Discoverer: LocalDiscoverer
[2024-07-26T19:32:07.267Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/BROKER: Serializer: EJSONSerializer
[2024-07-26T19:32:07.283Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/BROKER: Validator: FastestValidator
[2024-07-26T19:32:07.287Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/BROKER: Registered 13 middleware(s).
[2024-07-26T19:32:07.289Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/BROKER: Transporter: TcpTransporter
{"level":51,"time":"2024-07-26T19:32:07.338Z","pid":1,"hostname":"eb89009f7138","name":"DatabaseWatcher","msg":"Using change streams"}
[2024-07-26T19:32:07.360Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/TRANSIT: Connecting to the transporter...
[2024-07-26T19:32:07.375Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/TRANSPORTER: TCP server is listening on port 44956
[2024-07-26T19:32:07.376Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/TRANSPORTER: UDP Discovery is disabled.
[2024-07-26T19:32:07.377Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/TRANSPORTER: TCP Transporter started.
{"level":51,"time":"2024-07-26T19:32:08.734Z","pid":1,"hostname":"eb89009f7138","name":"License","msg":"License installed","version":"3.0","hash":"lxNsHloc"}
[2024-07-26T19:32:08.908Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/REGISTRY: '$node' service is registered.
[2024-07-26T19:32:08.910Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/REGISTRY: 'matrix' service is registered.
[2024-07-26T19:32:08.911Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/$NODE: Service '$node' started.
[2024-07-26T19:32:08.911Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/MATRIX: Service 'matrix' started.
[2024-07-26T19:32:08.912Z] INFO  53773364-68b1-47a8-b6fd-81376fa17113/BROKER: ✔ ServiceBroker with 2 service(s) started successfully in 1s.
ufs: temp directory created at "/tmp/ufs"
|                  SERVER RUNNING                 |
|  Rocket.Chat Version: 6.10.0                    |
|       NodeJS Version: 14.21.3 - x64             |
|      MongoDB Version: 5.0.24                    |
|       MongoDB Engine: wiredTiger                |
|             Platform: linux                     |
|         Process Port: 3000                      |
|             Site URL: http://10.100.10.36:3000  |
|     ReplicaSet OpLog: Enabled                   |
|          Commit Hash: 623a265851                |
|        Commit Branch: HEAD                      |
At least one bug open on this.
Check github.
Also I strongly advise to use 6.10.1 for a security fix.
Updated to 6.10.1 but still the same issue.
Also getting this in docker logs now for the container:
|                  SERVER RUNNING                 |
|  Rocket.Chat Version: 6.10.1                    |
|             Platform: linux                     |
|          Commit Hash: 636382f57e                |
{"level":51,"time":"2024-07-29T23:59:08.564Z","pid":1,"hostname":"8bc21ca16b20","name":"License","msg":"License installed","version":"3.0","hash":"MFrZItnI"}
{"level":50,"time":"2024-07-29T23:59:16.161Z","pid":1,"hostname":"8bc21ca16b20","name":"System","msg":"Failed to communicate with Rocket.Chat Cloud","url":"https://releases.rocket.chat/v2/server/supportedVersions","err":{"type":"AbortError","message":"The user aborted a request.","stack":"AbortError: The user aborted a request.\n    at abort (/app/bundle/programs/server/npm/node_modules/@rocket.chat/server-fetch/node_modules/node-fetch/lib/index.js:1401:16)\n    at AbortSignal.abortAndFinalize (/app/bundle/programs/server/npm/node_modules/@rocket.chat/server-fetch/node_modules/node-fetch/lib/index.js:1416:4)\n    at AbortSignal.dispatchEvent (/app/bundle/programs/server/npm/node_modules/event-target-shim/dist/event-target-shim.js:818:35)\n    at abortSignal (/app/bundle/programs/server/npm/node_modules/abort-controller/dist/abort-controller.js:52:12)\n    at AbortController.abort (/app/bundle/programs/server/npm/node_modules/abort-controller/dist/abort-controller.js:91:9)\n    at Timeout.<anonymous> (/app/bundle/programs/server/npm/node_modules/@rocket.chat/server-fetch/dist/index.js:37:51)\n    at listOnTimeout (internal/timers.js:557:17)\n    at processTimers (internal/timers.js:500:7)\n => awaited here:\n    at Function.Promise.await (/app/bundle/programs/server/npm/node_modules/meteor/promise/node_modules/meteor-promise/promise_server.js:56:12)\n    at app/cloud/server/functions/supportedVersionsToken/supportedVersionsToken.ts:46:17\n    at /app/bundle/programs/server/npm/node_modules/meteor/promise/node_modules/meteor-promise/fiber_pool.js:43:40","name":"AbortError"}}
{"level":51,"time":"2024-07-30T00:00:34.875Z","pid":1,"hostname":"8bc21ca16b20","name":"License","msg":"License installed","version":"3.0","hash":"33R2HoSs"}
Your server is runnung but your configuration is wrong.
Http is ONLY for localhost testing.
Use a reverse proxy + ssl/https.
Likely an issue with firewalling and tied to the previous comment.
Can you explain this more.
No, but the documentation can.
https://docs.rocket.chat/v1/docs/deploy-with-docker-docker-compose
For the Enable HTTPs section in the above link, I have a question about domain:
  • DOMAIN: Your domain or subdomain name only. Avoid adding https:// or any trailing slashes. Confirm that this domain resolves to the server IP address.
Can I just input a domain I want (for example: aquarium.uhtasi.local) without having to actually own or purchase the domain? How do I “confirm that this domain resolves to the server IP address”?
If you know, thanks for the help!
Yes, but you still need a proxy + ssl certificate to use https. Read about self signed certificates.
Note also that if Rocket detects an network it will want to register with a proper internet resolvable domain. They are cheap to buy!
There is a specific method to use if you really want it airgapped with no internet connection. Read the docs.
[quote]How do I “confirm that this domain resolves to the server IP address”?
[/quote]
This is a general networking question and the interwebs are full of pages on it.
Since aquarium.uhtasi.local is only accessible internally, I believe I shouldn’t have to purchase it. Instead I added it to my /etc/hosts file as so:
127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4
::1         localhost localhost.localdomain localhost6 localhost6.localdomain6
10.100.10.36    aquarium.uhtasi.local
ping-ing the domain shows that it does indeed correspond to the server IP (10.100.10.36):
[root@ELK-Stack rocketchat]# ping aquarium.uhtasi.local
PING aquarium.uhtasi.local (10.100.10.36) 56(84) bytes of data.
64 bytes from aquarium.uhtasi.local (10.100.10.36): icmp_seq=1 ttl=64 time=0.075 ms
64 bytes from aquarium.uhtasi.local (10.100.10.36): icmp_seq=2 ttl=64 time=0.072 ms
64 bytes from aquarium.uhtasi.local (10.100.10.36): icmp_seq=3 ttl=64 time=0.130 ms
^C
--- aquarium.uhtasi.local ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2004ms
rtt min/avg/max/mdev = 0.072/0.092/0.130/0.027 ms
I updated my .env file as so:
### Rocket.Chat configuration
# Rocket.Chat version
# see:- https://github.com/RocketChat/Rocket.Chat/releases
RELEASE=6.10.1
# MongoDB endpoint (include ?replicaSet= parameter)
#MONGO_URL=
# MongoDB endpoint to the local database
#MONGO_OPLOG_URL=
# IP to bind the process to
BIND_IP=127.0.0.1
# URL used to access your Rocket.Chat instance
ROOT_URL=https://aquarium.uhtasi.local
# Port Rocket.Chat runs on (in-container)
#PORT=
# Port on the host to bind to
#HOST_PORT=
### MongoDB configuration
# MongoDB version/image tag
#MONGODB_VERSION=
# See:- https://hub.docker.com/r/bitnami/mongodb
### Traefik config (if enabled)
# Traefik version/image tag
#TRAEFIK_RELEASE=
# Domain for https (change ROOT_URL & BIND_IP accordingly)
DOMAIN=aquarium.uhtasi.local
# Email for certificate notifications
LETSENCRYPT_EMAIL=roman@uhtasi.org
Creating the new container shows this in the logs:
|                  SERVER RUNNING                 |
|             Platform: linux                     |
{"level":51,"time":"2024-07-31T19:20:49.907Z","pid":1,"hostname":"0a6c64d8fd87","name":"License","msg":"License installed","version":"3.0","hash":"7Un7R1Co"}
Running the traefik-related command does return an error however:
[root@ELK-Stack rocketchat]# docker compose -f traefik.yml up -d
WARN[0000] Found orphan containers ([rocketchat-rocketchat-1 rocketchat-mongodb-1]) for this project. If you removed or renamed this service in your compose file, you can run this command with the --remove-orphans flag to clean it up.
[+] Running 0/1
 ⠼ Container rocketchat-traefik-1  Starting        3.4s
Error response from daemon: driver failed programming external connectivity on endpoint rocketchat-traefik-1 (9307f7e963a1208f9fc03e1a4630085444c19114da5d313538982517f2769d76): Error starting userland proxy: listen tcp4 0.0.0.0:443: bind: address already in use
However I still cannot access Rocket.Chat in the browser. I am trying the following URLs:
http://10.100.10.36:3000/
results in:
This site can’t be reached
10.100.10.36 took too long to respond.
Try:
  • Checking the connection
  • Checking the proxy and the firewall
  • Running Windows Network Diagnostics
ERR_CONNECTION_TIMED_OUT
while
https://aquarium.uhtasi.local/
results in:
aquarium.uhtasi.local’s server IP address could not be found.
Try:
  • Checking the proxy, firewall, and DNS configuration
ERR_NAME_NOT_RESOLVED
Any idea what the fix could be?
Yes, and the answers are already here but you aren’t trying to read and learn.
Don’t use http/3000 UNLESS you are testing on your own localhost. Rocket is not a web server. It’s an application that speaks via a websocket.
Put the server on a separate machine VM.
Site URL: https://your.domain.name
Don’t use an IP or 3000. Rocket is not designed for that.
Use a reverse proxy.
Learn how reverse proxies and self signed certificates work.
Don’t use traefik unless you know what you are doing… It’s probably tricky to use a self signed certificate.
Use nginx with a self signed SSL certificate and reverse proxy to your IP.
All this is documented at docs.rocket - change “letsencrypt” cert to “self signed” or do a general interweb search.
Also 6.10.2 might help.
