Absent 'Connectivity services'
I try to setup push notifications, so I created token on Rocket.Chat cloud (https://cloud.rocket.chat) and now have to input ‘Registration Token’ in ‘Administration → Connectivity Services’, but such chapter is absent:
Please, advise me how to get access to ‘Connectivity Services’ chapter.
I’m having this problem as well. There is no place to input the cloud token. Without this, notifications do not work. Anyone find the connectivity services tab or where to input the token?
Hi Yuriy! Did you solve your issue? Facing the same issue. In order to access marketplace, need to register my instance on cloud, but cannot find Connectivity Services.
Also having this issue
You don’t need to do this unless you run your own push notification service (and you would need to compile your own apps).
It works out of the box with no input required - if it doesn’t you have a setup issue.
Note push notifications are limited to 10,000 in CE & Starter supported versions (the last 6 versions)
No, you cannot buy more, and that will not change.
The issue is that push notifications are not working out of the box. I’ve also tried reconnecting and recreating the cloud link a few times with no luck either. Everything list listed as correct yet, no push notifications.
I’ve asked the team to look.
I’m on vacation later today.
thanks, feel i’ve been going in circles trying to figure out why even tests are not coming through, everything ‘should’ be working.
