my Rocket.Chat server looks like this:
- Version of Rocket.Chat Server: 3.6.0
- Operating System: Ubuntu 18.04 LTS
- Deployment Method: tar
- NodeJS Version: 12.22.1
- npm: 6.14.12
- MongoDB Version: 3.6.3
I try to upgrade my Rocket.Chat to version 4.1.1 because it has the same requirements as mine, according this document Updating Rocket.Chat - Rocket.Chat Docs.
There is a step
cd /tmp/bundle/programs/server && npm install
when I execute command npm install I get
npm WARN deprecated node-pre-gyp@0.14.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
> fibers@4.0.3 install /opt/rocket/bundle/programs/server/node_modules/fibers
> node build.js || nodejs build.js
internal/modules/cjs/loader.js:818
throw err;
Error: Cannot find module '/opt/rocket/bundle/programs/server/node_modules/fibers/build.js'
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
at Function.Module._load (internal/modules/cjs/loader.js:667:27)
at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
at internal/main/run_main_module.js:17:47 {
code: 'MODULE_NOT_FOUND',
requireStack: []
module.js:549
throw err;
at Function.Module._resolveFilename (module.js:547:15)
at Function.Module._load (module.js:474:25)
at Function.Module.runMain (module.js:693:10)
at startup (bootstrap_node.js:188:16)
at bootstrap_node.js:609:3
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! fibers@4.0.3 install: `node build.js || nodejs build.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the fibers@4.0.3 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2023-11-15T11_43_17_449Z-debug.log
Could you help me to fix this problem?
