I have Rocket Chat deployed on a self-hosted server, and generally things are working fine. However, if a user goes through the password reset workflow, they eventually get a ‘token expired’ error and can’t finish the process.
User clicks the ‘Forgot your password?’ link on the login screen
User enters email in the field and clicks ‘send instructions’
User finds the Password Recovery email and clicks the ‘Reset’ button
User enters a new password and is prompted for an authentication code in a new email
User finds the authentication code from the email and enters it
The Authentication Code prompt disappears and the password field now has an error message underneath it that says ‘Token expired’:
"level": 50,
"time": "2023-01-20T20:42:35.212Z",
"pid": 1091,
"hostname": "*redacted*",
"name": "System",
"msg": "Exception while invoking method resetPassword",
"err": {
"type": "errorClass",
"message": "Token expired [403]",
"stack": "Error: Token expired [403]<br> at packages/accounts-password/password_server.js:598:15<br> at tryLoginMethod (packages/accounts-base/accounts_server.js:1518:14)<br> at AccountsServer._loginMethod (packages/accounts-base/accounts_server.js:508:7)<br> at MethodInvocation.resetPassword (packages/accounts-password/password_server.js:566:19)<br> at maybeAuditArgumentChecks (packages/ddp-server/livedata_server.js:1885:12)<br> at packages/ddp-server/livedata_server.js:1803:15<br> at Meteor.EnvironmentVariable.EVp.withValue (packages/meteor.js:1257:12)<br> at packages/ddp-server/livedata_server.js:1801:36<br> at new Promise (<anonymous>)<br> at Server.applyAsync (packages/ddp-server/livedata_server.js:1800:12)<br> at Server.apply (packages/ddp-server/livedata_server.js:1739:26)<br> at Server.call (packages/ddp-server/livedata_server.js:1721:17)<br> at Object.post (app/api/server/v1/misc.ts:612:27)<br> at app/api/server/api.js:463:96<br> at Meteor.EnvironmentVariable.EVp.withValue (packages/meteor.js:1257:12)<br> at Object._internalRouteActionHandler [as action] (app/api/server/api.js:463:39)<br> at Route._callEndpoint (packages/rocketchat_restivus/lib/route.coffee:150:32)<br> at packages/rocketchat_restivus/lib/route.coffee:59:33<br> at packages/simple_json-routes.js:100:9<br> => awaited here:<br> at Promise.await (/snap/rocketchat-server/1536/programs/server/npm/node_modules/meteor/promise/node_modules/meteor-promise/promise_server.js:60:12)<br> at Server.apply (packages/ddp-server/livedata_server.js:1752:22)<br> at Server.call (packages/ddp-server/livedata_server.js:1721:17)<br> at Object.post (app/api/server/v1/misc.ts:612:27)<br> at app/api/server/api.js:463:96<br> at Meteor.EnvironmentVariable.EVp.withValue (packages/meteor.js:1257:12)<br> at Object._internalRouteActionHandler [as action] (app/api/server/api.js:463:39)<br> at Route._callEndpoint (packages/rocketchat_restivus/lib/route.coffee:150:32)<br> at packages/rocketchat_restivus/lib/route.coffee:59:33<br> at packages/simple_json-routes.js:100:9",
"isClientSafe": true,
"error": 403,
"reason": "Token expired",
"errorType": "Meteor.Error"
"msg": "Token expired [403]"
Reformatting that stack trace for easier readability:
=> awaited here:
