I am trying to convert a team to a channel but I receive an error: “team-does-not-exist”. I have noticed this error a few more times but does not happen always. I tried both via the interface and the API. Attached are the screenshots of the interface with the error corresponding to the team I am trying to convert. I would like to share the corresponding logs but being a new user this platform does not allow me to.
Hi! Sorry for the late response here.
Please, always provide what version you are running and all the template required infos ![]()
This was probably fixed in 5.4. For reference
Let me know if this helps!
Hi @dudanogueira, not a problem.
I should have added the details to the post itself. Tried editing it later but I do not see an option to do so. Anyway, following are the details,
Steps to reproduce:
Reproduction is difficult, given that there are several teams created that were easily converted to channel without any issue. The process to create the channel is as follows,
- Create a team with three users (User 1, User 2, Admin). API used: /teams.create, type: 0
- Call the API /teams.convertToChannel to convert the team to channel. The team name is used to perform this operation. (Also tried with team_id after the failure but it did not work).
Expected behavior:
The team should be converted to a channel.
Actual behavior:
Server Setup Information:
- Version of Rocket.Chat Server: 4.8.7 (also updated to 5.4.0, the issue remains as is)
- Operating System: Ubuntu 20.04
- Deployment Method: Snap
- DB Replicaset Oplog: As per Snap installation
- NodeJS Version: As per Snap installation
- MongoDB Version: As per Snap installation
Client Setup Information
- Desktop App or Browser Version: Primary - API call (Python), Firefox, Chrome
