alb
July 28, 2021, 3:27pm
1
Hi, I found a (supposed) bug in the subscription to stream-notify-room in realtime api.
I followed the instruction to subscribe to ‘typing ’ (a event of stream-notify-room) but instead of receive ‘ready’ answer I receive ‘nosub ’.
I used ddp lib that provides the unique subscription-id. The others parameters are in the format specified by the documentation (https://developer.rocket.chat/api/realtime-api/subscriptions/stream-notify-room ).
Is it an error of RocketChat server or do I make a mistake? Thanks
Version of Rocket.Chat Server: 3.15.0
Operating System: Ubuntu 20.04.2
Deployment Method: snap
DB Replicaset Oplog: Enabled
NodeJS Version: 12.22.1
MongoDB Version: 3.6.14
Proxy: nginx
Firewalls involved: none
To replicate the issue:
1 creation of ddp client using ddp lib
2 connection to server using ddp client
3 login with ddp client using ddp-login lib
4 register the guest (call to livechat:registerGuest)
5 send the first message that creates the room (call to sendMessageLivechat)
6 subscription
ddpClient.subscribe("stream-notify-room", [roomId+"/typing", false], () => { console.log("subscription"); } );
7 listen to new message
Hi.
Before you do anything, please use the latest version of Rocket.Chat to test - you can easily spin up a docker instance. You are going to get asked to do that if you report a bug.
Test on that and see if you can replicate the issue.
alb
July 29, 2021, 8:46am
4
Thanks John. I’ve update to the latest version (3.16.3) but the issue endures.
OK, think you opened this as a bug here:
opened 07:53AM - 30 Jul 21 UTC
closed 02:00PM - 24 Aug 21 UTC
### Description:
Hi, I found a (supposed) bug in the subscription to **stream-n… otify-room** in realtime api.
I followed the instruction to subscribe to ‘**typing**’ (a event of stream-notify-room) but instead of receive ‘ready’ answer I receive ‘**nosub**’.
I used **ddp** lib that provides the unique subscription-id. The others parameters are in the format specified by the documentation ( https://developer.rocket.chat/api/realtime-api/subscriptions/stream-notify-room)
### Steps to reproduce:
6 subscription
`ddpClient.subscribe("stream-notify-room", [roomId+"/typing", false], () => { console.log("subscription"); } );`
### Expected behavior:
receive` { msg: 'ready', subs: [ '`_number_`' ] }`
### Actual behavior:
receive `{ msg: 'nosub', id: '`_number_`' }`
### Server Setup Information:
Version of Rocket.Chat Server: 3.16.4
Proxy: nginx
In the issue you opened you mentioned this as well:
Expected behavior:
receive { msg: 'ready', subs: [ ' number ' ] }
Actual behavior:
receive { msg: 'nosub', id: ' number ' }
I need to try and get someone more knowledgeable than me to look. Please bear with me.
alb
August 11, 2021, 2:04pm
6
Hi John, yes it was me.
Also in the latest version (3.17.0) there is the same problem.
Thank you very much
