I performed the installation on Digital Ocean using the “1-Click Install” method, but I’m having an issue with SSL. After following the entire installation process as follows:
- Install via Market Place DO - marketplace.digitalocean.com/apps/rocket-chat
- I changed the DNS record and waited for propagation.
- docs.rocket.chat/deploy/deploy-rocket.chat/additional-deployment-methods/digitalocean#enabling-https
- docs.rocket.chat/deploy/deploy-rocket.chat/deploy-with-docker-and-docker-compose#enable-https
The SSL is not installed.
When accessing with https:// → sub.domain, it displays the error “404 Page Not Found.”
If I access with https:// → sub.domain.com with :3000, it shows “ERR_CONNECTION_REFUSED.”
If I access with http or https:// → droplet-ip:3000, it presents “ERR_CONNECTION_REFUSED.”
However, yesterday I was able to access https:// → droplet-ip:3000 and I performed the setup wizard.
How should I proceed? I see that the issue is related to SSL.
- Operating System: Ubunto 20.04
- Deployment Method: 1 click install
- DB Replicaset Oplog: ?
- NodeJS Version: 14.21.3
- MongoDB Version: 5.0.6
- Proxy: traefik ?
- Firewalls involved: ?
In the past, I also installed version 2.4 on Digital Ocean via 1-Click Install and didn’t have any problems; it still works fine today. I read about performing a manual installation, but it’s beyond my technical knowledge.
