SSL certificate
Hi there,
I found out that the last version of R.C demands ssl certificate in order to transmit audio and video messages. What if I just want to use the chat in the local network?
You can get your self a letsencrypt certificate for free.
You can generate a letsencrypt wildcard certificate for a domain then use that internally which might be useful.
I believe the SSL requirement is from the underlying video and audio library, not rocket.chat it self.
Thank you!
Could you help with internally using of certificate ? I mean how to use it if machine doesn’t have web server and DNS server?
