Number of Running Instances: Rocket.Chat Version: 3.15.0
DB Replicaset Oplog:
NodeJS Version: 12.22.1 - x64
MongoDB Version: 4.0.24
Proxy: nginx
Hello, When sending a test email, there is such an error in the logs:
The $MAIL_URL is ‘smtp://…:465’. You probably want ‘smtps://’ (The ‘s’ enables TLS/SSL) since ‘465’ is typically a secure port. undefined
I20211001-07:29:00.225(0) Exception in defer callback: Error: Greeting never received at SMTPConnection._formatError (/app/bundle/programs/server/npm/node_modules/meteor/email/node_modules/nodemailer/lib/smtp-connection/index.js:784:19) at SMTPConnection._onError (/app/bundle/programs/server/npm/node_modules/meteor/email/node_modules/nodemailer/lib/smtp-connection/index.js:770:20) at Timeout. (/app/bundle/programs/server/npm/node_modules/meteor/email/node_modules/nodemailer/lib/smtp-connection/index.js:704:22) at listOnTimeout (internal/timers.js:554:17) at processTimers (internal/timers.js:497:7) { code: ‘ETIMEDOUT’, command: ‘CONN’ }
Hello.
I set up SMTP on the Rocketchat interface, not in docker.On your advice, I changed the port from 465 to 587 and test emails began to arrive.Thanks for the help
