Scale MongoDB with AWS
I am inexperienced with MongoDB, I know little.
I use Mongodb with Rocket.Chat
https://docs.rocket.chat/quick-start/scaling-rocket.chat/running-multiple-instances
I have an AWS instance running Rocket.Chat and MongoDB at the same time locally.
I know that if I want to scale Rocket.Chat to be able to support more traffic, I only have to activate autoscaling, if the CPU is filled to 60%, new copies of the same instance are created, I know how to do that, my question is: what will happen to the database?
Let’s say that I duplicate my instance, I suppose that if I send a message it will be sent in one instance, it will not be duplicated in both, right?
Is there a way for me to keep many moingodb DB instances connected?
  • Version of Rocket.Chat Server: 4.7.4
  • Deployment Method: AWS Marketplace: Rocket.Chat Server
  • NodeJS Version: 14.18.3 - x64
  • MongoDB Version: 5.0.9
  • MongoDB Engine: wiredTiger
Have you seen this doc? It’s probably what you want for scaling MONGODB:
I understand the basics of MongoDB. So I will appreciate any kind of information.
What I want is to scale my database with multiple servers. It’s possible? Because if I have only one server, it has a capacity limit. What do you recommend me to do?
I know about replicas, but they’re so you don’t lose data on an instance, it doesn’t allow you to scale the database, does it?
Discussion continued here: Rocket.Chat
:slight_smile:
