Running in a sub folder with nginx
Hello everyone,
I am trying to run rocket.chat behind a nginx reverse proxy but in a subfolder… the configuration that is shown in the documentation works but only on “location /” and we would like to use “location /chat”.
My nginx configuration is as follow:
Upstreams
upstream backend {
server 127.0.0.1:3000;
Default server configuration
server {
listen 80 default_server;
listen 443 ssl default_server;
include snippets/self-signed-cert.conf;
root /var/www/html;
index index.html index.htm index.nginx-debian.html;
server_name xxxxxxxx;
location /chat {
proxy_pass http://backend/;
proxy_http_version 1.1;
proxy_set_header Connection “upgrade”;
            proxy_redirect off;
I get a bunch of lines like the following:
[error] 26822#26822: *5 open() “/var/www/html/sounds/highbell.mp3” failed (2: No such file or directory), client: yyy.yyy.yyy.yyy, server: xxx.xxx.xxx.xxx, request: “GET /sounds/highbell.mp3 HTTP/1.1”, host: “xxx.xxx.xxx.xxx”, referrer: “http://xxx.xxx.xxx.xxx/chat/”
Anybody has any idea?
Thanks in advance for any help on this matter.
Regards.
Sounds like inside Rocket.Chat you need to make sure you set your site URL to yourdomain.com/chat
Its attempting to access assets at yourdomain.com/
Thanks for your reply aaron.ogle,
I’ve tried doing the change you suggest but still I get the same result…
Any other ideas?
You restarted right after as well?
Yes of course aaron.ogle! :slight_smile: , both nginx and rocket.chat… but still the same result. I am losing my head here… I really don’t get it. If I use “location /” on my nginx configuration and “https://IP_ADDRESS” on site URL on my rocket.chat installation it works perfectly!, the only thing I would have to change is “location /chat” on nginx configuration and “https://IP_ADDRESS/chat” on rocket.chat URL configuration! (right???)
Thanks for the help on this!
Does anybody know how to change the following apache configuration to nginx:
<Location /chat>
Order allow,deny
Allow from all
RewriteEngine On
RewriteRule /var/www/(.*)           ws://localhost:3000/$1 [P,L]
RewriteRule /var/www/(.*)           http://localhost:3000/$1 [P,L]
ProxyPassReverse http://localhost:3000
Take a look here: https://rocket.chat/docs/installation/manual-installation/configuring-ssl-reverse-proxy/#running-behind-a-nginx-ssl-reverse-proxy
Basically something like this I think should do the trick:
location ~/chat(.*)$ {
        proxy_pass http://backend/$1;
        proxy_redirect off;
I haven’t tried. Not a big fan of subfolder :slight_smile:
