Hi.
I’m trying to host rocket chat in a subfolder using nginx as a reverse proxy server. I set up the rocketchat.service file so that it works properly with ROOT_URL=http://localhost
Then I changed that to ROOT_URL=http://localhost/chat and added these rules to the nginx configuration file.
location ~* “^/[a-z0-9]{40}.(css|js)$” {
root /opt/rocket/Rocket.Chat/programs/web.browser;
access_log off;
expires max;
}location ~ ^/packages {
access_log off;
}location ~ ^/(images|sounds|assets|sockjs|fonts|theme|__meteor__) {
rewrite ^ /chat$uri;
}location /chat {
proxy_http_version 1.1;proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "upgrade"; proxy_set_header Host $http_host; proxy_set_header X-Real-IP $remote_addr; proxy_set_header X-Forward-For $proxy_add_x_forwarded_for; proxy_set_header X-Forward-Proto http; proxy_set_header X-Nginx-Proxy true; proxy_pass http://localhost:3000/chat; proxy_redirect off;}
There are no 404 errors, but I’m getting what looks like an ajax error from the server. How can I debug this?
Update: Apparently this occurs when the client is expecting a json response but receives html.
- Version of Rocket.Chat Server: 3.0.4
- Operating System: Ubuntu 18.04 TLS
- Deployment Method: tar
- DB Replicaset Oplog: rs01
- NodeJS Version: 12.14.0
- MongoDB Version: 4.2.6
- Proxy: nginx
- Firewalls involved: ubuntu
