Problems with reverse proxy
Hello community:
I have installed Rocket.Chat in a Debian 10 container on Proxmox and access it well through http: // my_domain: 300.
When I configured reverse proxy in nginx and tried to access via https: // my_domain it doesn’t work. The tuto that is found in https://docs.rocket.chat/installation/manual-installation/debian
I have the same problem. Installed everything one week ago but on Ubuntu 20.04 LTS.
Any advice?
Hey, I just solved the problem.
Those who were configuring the Rocket-Chat-Server with an Nginx-Reverse-Proxy by following the official installation manual should edit the Nginx-Config: /etc/nginx/sites-enabled/default
Then edit the line where it says
proxy_pass http://backend/
and change it to
This solved my problem. I hope I could help anyone.
Excellent, problem solved, thanks. :+1: :+1: :+1:
In apache2 it gives the same error.
How would it be?
Hola,
On CentOS 7.8 running Apache 2.4.6 I added the following for the Rocket.Chat Virtualhost on port 443 in httpd.conf:
RewriteEngine On
RewriteRule /(.) ws://localhost:3000/$1 [P,L]
RewriteRule /(.
) http://localhost:3000/$1 [P,L]
ProxyPassReverse / http://localhost:3000/
Best regards,
Matt
The individuals who were arranging the Rocket-Chat-Server with a Nginx-Reverse-Proxy by following the official establishment manual ought to alter the Nginx-Config:/and so forth/nginx/locales empowered/default
