Hello, it appears that when I run rocketchat through a reverse proxy (to enable SSL), the website loads extremely slowly. Please compare:
https://study.gjk.cat
http://study.magnusi.tech:3000
Regular HTTP & No Proxy is quite fast. I don’t know what’s causing it, please advise. I tried both nginx and caddy, currently using caddy with this config:
*:80 {
gzip
root /usr/share/caddy
study.gjk.cat {
proxy / 127.0.0.1:3000 {
header_upstream X-Forwarded-Proto {scheme}
header_upstream X-Forwarded-For {host}
header_upstream Host {host}
websocket
import conf.d/*.conf
And RocketChat is running with these variables:
DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/0/bus
EDITOR=nano
HOME=/root
LANG=en_US.UTF-8
LOGNAME=root
MAIL=/var/spool/mail/root
MONGO_OPLOG_URL=mongodb://localhost:27017/local?replSet=rs01
MONGO_URL=mongodb://localhost:27017/rocketchat
PATH=/root/.cargo/bin:/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
PWD=/usr/share/rocketchat-server
SHELL=/usr/bin/fish
SHLVL=1
STARSHIP_SHELL=fish
TERM=xterm-256color
XDG_RUNTIME_DIR=/run/user/0
XDG_SESSION_CLASS=user
XDG_SESSION_ID=22
XDG_SESSION_TYPE=tty
ROOT_URL=https://style.gjk.cat
NODE_ENV=production
PORT=3000
- Version of Rocket.Chat Server: 3.0.4
- Operating System: Arch Linux
- Deployment Method: AUR Package
- DB Replicaset Oplog: enabled per tutorial
- NodeJS Version: 12.16.1
- MongoDB Version: 4.2.3
- Proxy: nginx/caddy
- Firewalls involved: none
