Rocketchat not starting returning exited code 1
Description:
Hello all,
After a reboot, rocketchat is not starting correctly :
rocketchatdevelop_rocketchat_1 exited with code 1
I stopped all mongo process and start mongo, same result.
Server Setup Information:
Operating System: Debian 7.11
Deployment Method(snap/docker/tar/etc): docker
mongoDB Version: db version v2.0.6, pdfile version 4.5
Steps to Reproduce:
kill mongod process
To be sure : ps aux | grep mongod
service mongod start
docker-compose up rocketchat
Expected behavior:
rocketchat up and running
Actual behavior:
        /usr/src/Rocket.Chat-develop# docker-compose up rocketchat
        Starting rocketchatdevelop_mongo_1
        Starting rocketchatdevelop_rocketchat_1
        Attaching to rocketchatdevelop_rocketchat_1
        rocketchat_1 |
        rocketchat_1 | /app/bundle/programs/server/node_modules/fibers/future.js:313
        rocketchat_1 | throw(ex);
        rocketchat_1 | ^
        rocketchat_1 | MongoError: failed to connect to server [mongo:27017] on first connect [MongoError: connect ECONNREFUSED 172.17.0.2:27017]
        rocketchat_1 | at Pool. (/app/bundle/programs/server/npm/node_modules/meteor/npm-mongo/node_modules/mongodb-core/lib/topologies/server.js:336:35)
        rocketchat_1 | at emitOne (events.js:116:13)
        rocketchat_1 | at Pool.emit (events.js:211:7)
        rocketchat_1 | at Connection. (/app/bundle/programs/server/npm/node_modules/meteor/npm-mongo/node_modules/mongodb-core/lib/connection/pool.js:280:12)
        rocketchat_1 | at Object.onceWrapper (events.js:317:30)
        rocketchat_1 | at emitTwo (events.js:126:13)
        rocketchat_1 | at Connection.emit (events.js:214:7)
        rocketchat_1 | at Socket. (/app/bundle/programs/server/npm/node_modules/meteor/npm-mongo/node_modules/mongodb-core/lib/connection/connection.js:189:49)
        rocketchat_1 | at Object.onceWrapper (events.js:315:30)
        rocketchat_1 | at Socket.emit (events.js:211:7)
        rocketchat_1 | at emitErrorNT (internal/streams/destroy.js:64:8)
        rocketchat_1 | at _combinedTickCallback (internal/process/next_tick.js:138:11)
        rocketchat_1 | at process._tickCallback (internal/process/next_tick.js:180:9)
Relevant logs:
/var/log/mongodb/mongodb.log :
***** SERVER RESTARTED *****
Wed Mar 21 16:59:22 [initandlisten] MongoDB starting : pid=3037 port=27017 dbpath=/home/sites/chat.symbiose.fr/mongodb 64-bit host=atlantis
Wed Mar 21 16:59:22 [initandlisten] db version v2.0.6, pdfile version 4.5
Wed Mar 21 16:59:22 [initandlisten] git version: nogitversion
Wed Mar 21 16:59:22 [initandlisten] build info: Linux tigereye 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt20-1+deb8u3 (2016-01-17) x86_64 BOOST_LIB_VERSION=1_49
Wed Mar 21 16:59:22 [initandlisten] options: { bind_ip: "127.0.0.1", command: [ "run" ], config: "/etc/mongodb.conf", dbpath: "/home/sites/chat.symbiose.fr/mongodb", journal: "true", logappend: "true", logpath: "/var/log/mongodb/mongodb.log", unixSocketPrefix: "/var/run/mongodb" }
Wed Mar 21 16:59:22 [initandlisten] journal dir=/home/sites/chat.symbiose.fr/mongodb/journal
Wed Mar 21 16:59:22 [initandlisten] recover : no journal files present, no recovery needed
Wed Mar 21 16:59:22 [websvr] admin web console waiting for connections on port 28017
Wed Mar 21 16:59:22 [initandlisten] waiting for connections on port 27017
Wed Mar 21 16:59:40 [initandlisten] connection accepted from 127.0.0.1:38811 #1
Wed Mar 21 17:00:12 [conn1] end connection 127.0.0.1:38811
Wed Mar 21 17:00:22 [clientcursormon] mem (MB) res:18 virt:170 mapped:0
Wed Mar 21 17:02:00 [initandlisten] connection accepted from 127.0.0.1:39064 #2
Wed Mar 21 17:02:10 [conn2] end connection 127.0.0.1:39064
Wed Mar 21 17:02:10 [initandlisten] connection accepted from 127.0.0.1:39074 #3
Wed Mar 21 17:02:31 [conn3] end connection 127.0.0.1:39074
Wed Mar 21 17:05:22 [clientcursormon] mem (MB) res:18 virt:171 mapped:0
Wed Mar 21 17:10:22 [clientcursormon] mem (MB) res:18 virt:171 mapped:0
Wed Mar 21 17:15:22 [clientcursormon] mem (MB) res:18 virt:171 mapped:0
Wed Mar 21 17:20:22 [clientcursormon] mem (MB) res:18 virt:171 mapped:0
Wed Mar 21 17:24:02 got kill or ctrl c or hup signal 15 (Terminated), will terminate after current cmd ends
Wed Mar 21 17:24:02 [interruptThread] now exiting
Wed Mar 21 17:24:02 dbexit:
Wed Mar 21 17:24:02 [interruptThread] shutdown: going to close listening sockets...
Wed Mar 21 17:24:02 [interruptThread] closing listening socket: 6
Wed Mar 21 17:24:02 [interruptThread] closing listening socket: 7
Wed Mar 21 17:24:02 [interruptThread] closing listening socket: 8
Wed Mar 21 17:24:02 [interruptThread] removing socket file: /var/run/mongodb/mongodb-27017.sock
Wed Mar 21 17:24:02 [interruptThread] shutdown: going to flush diaglog...
Wed Mar 21 17:24:02 [interruptThread] shutdown: going to close sockets...
Wed Mar 21 17:24:02 [interruptThread] shutdown: waiting for fs preallocator...
Wed Mar 21 17:24:02 [interruptThread] shutdown: lock for final commit...
Wed Mar 21 17:24:02 [interruptThread] shutdown: final commit...
Wed Mar 21 17:24:02 [interruptThread] shutdown: closing all files...
Wed Mar 21 17:24:02 [interruptThread] closeAllFiles() finished
Wed Mar 21 17:24:02 [interruptThread] journalCleanup...
Wed Mar 21 17:24:02 [interruptThread] removeJournalFiles
Wed Mar 21 17:24:02 [interruptThread] shutdown: removing fs lock...
Wed Mar 21 17:24:02 dbexit: really exiting now
Thanks in advance!
Continuing the discussion from Rocketchat not starting returning exited code 1:
I changed the 172.17.0.2:27017 to localhost:27017 in docker-compose.yml : not better
As you can see from your mongo logs mongo isn’t starting up. Its actually getting killed it looks like before its finished according to this line:
Where can i find the reason why mongo is killed ? Increase verbosity log?
Last night i tried : docker-compose up -d rocketchat
and now its stuck at : Wed Mar 28 09:36:23 [clientcursormon] mem (MB) res:18 virt:169 mapped:0
mongodb.log :
Tue Mar 27 22:45:22 [initandlisten] MongoDB starting : pid=12556 port=27017 dbpath=/home/sites/chat.symbiose.fr/mongodb 64-bit host=atlantis
Tue Mar 27 22:45:22 [initandlisten] db version v2.0.6, pdfile version 4.5
Tue Mar 27 22:45:22 [initandlisten] git version: nogitversion
Tue Mar 27 22:45:22 [initandlisten] build info: Linux tigereye 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt20-1+deb8u3 (2016-01-17) x86_64 BOOST_LIB_VERSION=1_49
Tue Mar 27 22:45:22 [initandlisten] options: { bind_ip: “127.0.0.1”, command: [ “run” ], config: “/etc/mongodb.conf”, dbpath: “/home/sites/chat.symbiose.fr/mongodb”, journal: “true”, logappend: “true”, logpath: “/var/log/mongodb/mongodb.log”, unixSocketPrefix: “/var/run/mongodb” }
Tue Mar 27 22:45:22 [initandlisten] journal dir=/home/sites/chat.symbiose.fr/mongodb/journal
Tue Mar 27 22:45:22 [initandlisten] recover : no journal files present, no recovery needed
Tue Mar 27 22:45:22 [websvr] admin web console waiting for connections on port 28017
Tue Mar 27 22:45:22 [initandlisten] waiting for connections on port 27017
Tue Mar 27 22:46:22 [clientcursormon] mem (MB) res:18 virt:169 mapped:0
Tue Mar 27 22:51:22 [clientcursormon] mem (MB) res:18 virt:169 mapped:0
Wed Mar 28 09:41:23 [clientcursormon] mem (MB) res:18 virt:169 mapped:0
Those aren’t errors. Looks to me like it’s up and waiting for connections. See the line about listening. If it werent it would have exited
It looks like my rocketchat database is gone :frowning:
PRIMARY> show dbs
local 4.201171875GB
rocketchat (empty)
test (empty)
How my db can be empty?
What’s your docker-compose file look like? If you don’t mount your db volume… if you do any sort of remove on the containers data goes away.
Running: docker ps -a should give you a bit more info about how old containers are, to explain if maybe new container was created. Also let us see if old container happens to be around.
docker ps -a
CONTAINER ID        IMAGE                           COMMAND                  CREATED             STATUS                    PORTS                    NAMES
b16a617e7f93        rocketchat/rocket.chat:latest   "node main.js"           6 hours ago         Exited (1) 6 hours ago                             rocketchatdevelop_rocketchat_1
65f7920d2bf5        rocketchat/hubot-rocketchat     "/bin/sh -c 'node ..."   7 days ago          Exited (255) 7 days ago   0.0.0.0:3001->8080/tcp   rocketchatdevelop_hubot_1
98aadc581430        mongo                           "docker-entrypoint..."   7 days ago          Exited (62) 6 hours ago                            rocketchatdevelop_mongo_1
a5c7adc392c5        87bfde2fb77e                    "node main.js"           2 years ago         Exited (8) 2 years ago                             ecstatic_ardinghelli
Here is my docker-compose.yml :
mongo:
  image: mongo
  volumes:
    - /home/sites/chat.symbiose.fr/web/runtime/db:/data/db
    - /home/sites/chat.symbiose.fr/web/dump:/dump
  command: mongod --smallfiles --oplogSize 128
rocketchat:
  volumes:
    - /home/sites/chat.symbiose.fr/web/uploads:/app/uploads
    - PORT=3000
    - ROOT_URL=https://chat.symbiose.fr
  links:
    - mongo:mongo
  ports:
    - 3000:3000
hubot:
  image: rocketchat/hubot-rocketchat
    - ROCKETCHAT_URL=rocketchat:3000
    - ROCKETCHAT_ROOM=GENERAL
    - ROCKETCHAT_USER=bot
    - ROCKETCHAT_PASSWORD=botpassword
    - BOT_NAME=bot
    - EXTERNAL_SCRIPTS=hubot-help,hubot-seen,hubot-links,hubot-diagnostics
  links:
    - rocketchat:rocketchat
# this is used to expose the hubot port for notifications on the host on port 3000, e.g. for hubot-jenkins-notifier
  ports:
    - 3000:8080
Someone have an idea?
