Hey there,
We’re running a manuall installation of RocketChat (Version 0.63.3) on Ubuntu Server 16.04 LTS with LDAP Authentication (Login Fallback = False).
We’re trying to use Pidgin as the Client. Unfortunately it always says „Connection error: failure with https connection: SSL-Connection failed“. It’s a self signed certificate, i also imported it to pidgin.
The connection works over the Browser and also over the rocketchat client. So i don’t think it’s a Problem in generell.
Maybe my Apache config is not compatible with Pidgin?
You can see it here
<IfModule mod_ssl.c>
<VirtualHost _default_:443>
ServerAdmin helpdesk@domain.com
# ServerName rocketchat01
# DocumentRoot /var/www/html
ProxyPreserveHost On
ProxyRequests Off
ServerName rocketchat01.dk.de
ServerAlias https://rocketchat01.dk.de
ProxyPass / http://localhost:3000/
ProxyPassReverse / http://localhost:3000/
<Proxy *>
Order deny,allow
Allow from all
</Proxy>
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
SSLEngine on
SSLCertificateFile /etc/apache2/ssl/rocketchat01.crt
SSLCertificateKeyFile /etc/apache2/ssl/rocketchat01.key
<FilesMatch "\.(cgi|shtml|phtml|php)$">
SSLOptions +StdEnvVars
</FilesMatch>
<Directory /usr/lib/cgi-bin>
</Directory>
</VirtualHost>
</IfModule>
