Rocket chat snap install does not work
Server config: Ubuntu 16.04 server, 1GB RAM
I booked a server and installed rocket chat from snap. i tried IP_ADDRESS:300 and nothing happened.
I checked out the logs and there seems to be a problem with mongodb, I checked the logs and its shows this:
Was unable to connect to Mongo. Please make sure Mongo has started successfully: sudo systemctl status snap.rocketchat-server.rocketchat-mongo to view logs: sudo journalctl -u snap.rocketchat-server.rocketchat-mongo
then I tried
and it shows this
snap.rocketchat-server.rocketchat-mongo.service - Service for snap application rocketchat-server.rocketchat-mongo
Active: inactive (dead) (Result: exit-code) since Wed 2018-04-04 15:08:13 UTC; 38min ago
Process: 2314 ExecStart=/usr/bin/snap run rocketchat-server.rocketchat-mongo (code=exited, status=100)
Main PID: 2314 (code=exited, status=100)
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable
I am stuck. Any help will be appreciated.
Hi @karthik_ak!
Rather than Mongo’s service status, can you also post the actual logs?
You can view them by running sudo journalctl -u snap.rocketchat-server.rocketchat-mongo.
Jonas
Hello @frdmn,
Thanks for taking pains to reply me. I am not sure what I did, but I restarted mongo I think and it seems to be working now (I don’t know how).
I did collect the logs yesterday, you may have a look here rocket chat mongo error · GitHub
Thank rocket chat community a lot for them to have given us this excellent software :slight_smile:
The logs in your gist are just for the snap.rocketchat-server.rocketchat-server service rather than the snap.rocketchat-server.rocketchat-mongo one.
Anyways, if it happens again - try to collect those logs instead and post them here again. :+1:
