Hello everyone, I apologize for not finding any thread related to my problem. My experience with Linux and snapd is very limited.
VM machine:
snapd 2.60.4
series 16
ubuntu 22.04
kernel 5.15.0-86-generic
Wersja 6.0.0
Wersja silnika aplikacji 1.37.0-alpha.164
Wersja node’a v14.21.2
Migracja bazy danych 292 (17 października 2023 05:33)
MongoDB 5.0.15 / wiredTiger (oplog Włączone)
I set up a server several years ago during the installation of the system, which was version 4 or 3 at that time. One day, when updating the system, I changed the update channel to version 6. Since then, every time I update, the entire server crashes. After changing to version 5 (snap switch rocketchat-server --channel=5.x/stable), everything returns to normal. What can I do in this case? I tried to go through each version sequentially, but when I try to switch to version 6, I still have a problem. Recently, I received information that “Rocket.Chat workspace is now running an unsupported version of Rocket.Chat.”
Error - when update server
user@chat01:~$ sudo snap refresh
- Start snap "rocketchat-server" (1556) services (systemctl command [start snap.rocketchat-server.rocketchat-mongo.service] failed with exit status 1: Job for snap.rocketchat-server.rocketchat-mongo.service failed because the control process exited with error code.
See "systemctl status snap.rocketchat-server.rocketchat-mongo.service" and "journalctl -xeu snap.rocketchat-server.rocketchat-mongo.service" for details.
● snap.rocketchat-server.rocketchat-mongo.service - Service for snap application rocketchat-server.rocketchat-mongo
Active: active (running) since Tue 2023-10-17 12:22:43 UTC; 6min ago
Main PID: 17324 (mongod)
Tasks: 82 (limit: 4557)
Memory: 768.5M
CPU: 11.360s
CGroup: /system.slice/snap.rocketchat-server.rocketchat-mongo.service
└─17324 mongod --config=/var/snap/rocketchat-server/1545/mongod.conf --fork --syslog
chat01 systemd[1]: snap.rocketchat-server.rocketchat-mongo.service: Failed with result 'exit-code'.
chat01 systemd[1]: Failed to start Service for snap application rocketchat-server.rocketchat-mongo.
I would be very grateful for any guidance and help.
