Rocket.Chat and LiveKit Integration: External Students Receive “Invalid OAuth State” While Administrator Login Works — Seeking a Reliable Single Sign-On Solution
Technical Support Request: Rocket.Chat + LiveKit Integration Fails for External Students
1. Project overview
We are developing a self-hosted online classroom and trading education platform.
Our objective is to provide a classroom experience similar to Messenger or TikTok:
  • Students log into Rocket.Chat once.
  • Students communicate through Rocket.Chat channels.
  • Students click Join Live Classroom to enter a video classroom.
  • The instructor controls who can activate microphones and cameras.
  • Students join as viewers by default.
  • Students can request permission to speak.
  • The platform should work reliably on desktop and mobile browsers, including outside our local network.
We previously used Rocket.Chat with Jitsi Meet. Video meetings could be launched directly through Rocket.Chat’s camera button.
However, we experienced a permissions problem: ordinary students were receiving moderator privileges.
We subsequently developed a custom LiveKit classroom to implement stricter instructor controls.
The new LiveKit integration has a critical authentication problem.
2. Server environment
Operating system: Ubuntu 26.04 LTS
Hardware:
  • Intel Core i5-10500T
  • 32 GB RAM
  • 1 TB NVMe SSD
Infrastructure:
  • nginx reverse proxy
  • Let’s Encrypt HTTPS
  • Rocket.Chat 8.8.1 running in Docker
  • MongoDB 8.2
  • LiveKit media server
  • Custom Next.js 15.5.21 classroom application
  • Node.js and PM2
Application addresses
Rocket.Chat:
LiveKit classroom:
Classroom login:
OAuth callback:
The Next.js application runs locally on port 3202.
PM2 process:
classroom-new-release
Project directory:
/home/birhane/projects/livekit-meet-release-20261023
3. The main problem
The administrator can enter the LiveKit classroom, but an external student cannot.
Administrator:
  • Rocket.Chat username: LinuxAdmin
  • Can authenticate.
  • Can enter the LiveKit classroom.
  • Can see instructor controls.
External student:
  • Rocket.Chat username: Mieraf
  • Rocket.Chat account is active.
  • Can log into Rocket.Chat.
  • Can open the classroom page.
  • Can see the Join Room interface.
  • Encounters a white screen during the joining process.
  • Receives the error:
HTTP 403 — Invalid OAuth state
The student also tried opening the classroom login endpoint directly, without using the Rocket.Chat button.
The same error occurred.
The administrator can authenticate successfully through the normal login flow.
Opening the OAuth callback URL directly also produces Invalid OAuth state, which is expected because a direct request does not contain the required OAuth state.
4. Current authentication architecture
Rocket.Chat uses OAuth to authenticate users entering the Next.js classroom.
The login endpoint generates a random state:
const state = randomBytes(32).toString('hex');
It redirects the browser to Rocket.Chat:
const authorizationUrl = new URL('/oauth/authorize', rocketChatUrl);
authorizationUrl.searchParams.set('response_type', 'code');
authorizationUrl.searchParams.set('client_id', clientId);
authorizationUrl.searchParams.set('redirect_uri', redirectUri);
authorizationUrl.searchParams.set('state', state);
It sets the following cookie:
response.cookies.set('_oauth_state', state, {
  httpOnly: true,
  secure: true,
  sameSite: 'lax',
  path: '/api/auth/callback/rocketchat',
  maxAge: 900,
The callback retrieves the cookie:
const expectedState =
  request.cookies.get('_oauth_state')?.value;
const receivedState =
  request.nextUrl.searchParams.get('state');
It validates the values:
if (!validOAuthState(expectedState, receivedState)) {
  return reply('Invalid OAuth state', 403);
The validation function:
import { timingSafeEqual } from 'node:crypto';
export function validOAuthState(
  expected: string | undefined,
  received: string | null,
): boolean {
  if (!expected || !received) {
    return false;
  const a = Buffer.from(expected, 'utf8');
  const b = Buffer.from(received, 'utf8');
  if (a.length !== 64 || b.length !== 64) {
    return false;
  return timingSafeEqual(a, b);
The validation code appears reasonable, but we have not established whether the student is missing the cookie, receiving a different state, or encountering another browser-specific issue.
5. Rocket.Chat integration
Rocket.Chat contains a custom JavaScript button.
Relevant code:
  const BUTTON_ID = '-live-classroom-link';
  const LOGIN_URL =
    'https://meet/api/auth/login';
  if (window.__ClassroomButtonInitialized) return;
  window.__ClassroomButtonInitialized = true;
  const button = document.createElement('a');
  button.id = BUTTON_ID;
  button.href = LOGIN_URL;
  button.target = '_blank';
  button.rel = 'noopener noreferrer';
  button.textContent = '🎥 Join Live Classroom';
The actual script also styles the button and appends it to the document.
The button opens a new browser tab.
The student receives the same OAuth error when bypassing this button and visiting the login endpoint directly.
6. Verified OAuth configuration
The Next.js .env.local contains:
ROCKETCHAT_URL=https://
ROCKETCHAT_REDIRECT_URI=https:///api/auth/callback/rocketchat
Rocket.Chat’s MongoDB OAuth application configuration contains:
name: OSCE Academy Classroom
redirectUri:
https:///api/auth/callback/rocketchat,
https://api/auth/callback/rocketchat
active: true
Both the older classroom domain and the current meet domain are registered.
The current Next.js application uses the meet domain.
7. nginx configuration
The active classroom domain uses:
server {
    server_name ;
    auth_basic off;
    location / {
        proxy_pass http://127.0.0.1:3202;
        proxy_http_version 1.1;
        proxy_set_header Host $host;
        proxy_set_header X-Forwarded-Proto $scheme;
    listen 443 ssl;
HTTPS is active.
The reverse proxy forwards the host and protocol headers.
There is also an older nginx configuration for:
That configuration routes its OAuth callback to port 3202, but the main application currently uses the meet domain.
8. PM2 logs
The Next.js application starts successfully:
▲ Next.js 15.5.21
Local: http://127.0.0.1:3202
✓ Starting...
✓ Ready in 396ms
The error log repeatedly contains:
Local storage is not available.
No detailed OAuth state failure diagnostics were observed in the supplied PM2 logs.
We have not established whether the local-storage warnings are related to the authentication failure.
9. What has already been tested
  1. Administrator login works.
  2. Student Rocket.Chat login works.
  3. Student can open the classroom page.
  4. Student encounters a white screen and Invalid OAuth state.
  5. Closing classroom tabs and retrying did not solve the problem.
  6. Opening the login endpoint directly did not solve the problem.
  7. OAuth state generation and validation code were inspected.
  8. Cookie attributes were inspected.
  9. nginx reverse-proxy configuration was inspected.
  10. Rocket.Chat OAuth application registration was inspected.
Not yet verified:
  • Whether the student’s browser receives the Set-Cookie header.
  • Whether the browser stores osce_oauth_state.
  • Whether the cookie is included in the callback request.
  • Whether the callback’s returned state matches the originally generated state.
  • Whether multiple login requests overwrite the cookie.
  • Whether browser privacy settings interfere with the redirect.
  • Whether the production environment differs from the inspected source configuration.
10. Required solution
We do not want to disable OAuth state validation or weaken authentication security.
We want a stable, production-ready solution that:
  1. Allows Rocket.Chat users to enter the classroom without repeated authentication problems.
  2. Supports desktop and mobile browsers.
  3. Works for external students.
  4. Maintains secure authentication and session management.
  5. Keeps the administrator as the only instructor/moderator.
  6. Allows students to join as viewers.
  7. Allows instructors to grant microphone and camera permissions.
  8. Supports automatic reconnection after network interruptions.
  9. Does not require users to log into two separate applications unnecessarily.
We prefer an established open-source integration or proven implementation over writing extensive custom authentication code.
11. Questions for experienced developers
A. OAuth diagnosis
What is the most likely explanation for the OAuth state validation succeeding for the administrator but failing for an external student?
What is the fastest reliable method to determine whether the OAuth state cookie is missing, overwritten, or mismatched?
B. Architecture
Should we continue using Rocket.Chat OAuth with a custom Next.js LiveKit application?
Or is there a more reliable existing integration that allows Rocket.Chat to provide authentication while LiveKit provides video and audio?
C. Existing implementations
Are there maintained open-source projects demonstrating Rocket.Chat SSO integration with LiveKit, including instructor/participant roles?
Can we reuse their authentication and session-management approach rather than developing our own?
D. Alternative solution
Would Rocket.Chat’s native Jitsi integration with properly configured moderator roles and audio/video moderation be simpler and more reliable?
If so, what exact Jitsi configuration ensures that only the instructor receives moderator privileges while students remain ordinary participants?
12. Important constraints
  • This is a self-hosted system.
  • We want to avoid unnecessary cloud-service costs.
  • The existing Rocket.Chat installation must remain operational.
  • The current LiveKit application must not be deleted until a replacement has been tested.
  • Security protections must remain enabled.
  • We prefer minimal, tested configuration changes over extensive custom development.
Primary objective:
A student logs into Rocket.Chat, clicks one camera or classroom button, and joins a secure video classroom where only the instructor has moderator privileges.
We need a proven implementation that works consistently for external users.
I doubt anyone will give you the help you want for free. You are asking for full, in depth, technical support.
With a paid plan I’m sure Rocket would be happy to help.
However, as I guess you only want to use CE, no one is likely to help at this level free of charge. You should also read this and understand the implications for your use of Oauth.
Admin-works-external-fails points at the OAuth state being lost on the cross-domain redirect rather than at LiveKit itself. First check: is the state cookie SameSite=None and Secure, and does it survive the redirect chain? Does the admin login work from outside the local network too, or only from inside it?
Thank you for your response and your time.
I appreciate your feedback. Fortunately, I have already managed to find a solution to my problem, and my system is now working.
However, I would like to highlight something that I believe could be improved in Rocket.Chat, especially for educational platforms and online classrooms.
One important limitation is the lack of fully integrated, administrator-controlled audio and video conferencing.
For example, in an educational environment, an instructor should be able to:
  • Control which participants can activate their microphones and cameras.
  • Allow students to join as viewers by default.
  • Let students raise their hands and request permission to speak.
  • Grant or revoke microphone and camera permissions individually.
  • Manage everything directly within Rocket.Chat without depending on external systems such as Jitsi or LiveKit.
I am currently implementing these features using LiveKit alongside Rocket.Chat, but I believe having such functionality natively integrated would make Rocket.Chat much more attractive for educational institutions, training academies, and professional communities.
Perhaps some of these capabilities are already available in newer Rocket.Chat releases. If so, I would appreciate knowing about them.
I understand that Community Edition users cannot expect unlimited free technical support, and I respect that. My intention is simply to share practical feedback from someone actively building and testing a real-world system.
I believe identifying limitations and suggesting improvements can also benefit the Rocket.Chat development team and the wider community.
Thank you again for your time and for the work behind Rocket.Chat.
I doubt that will happen due to overhead.
Essentially you want to bolt video conferencing directly into Rocket. They are not going to buy Jitsi!
They took the decision some time ago to stick at what they were good at - messaging - and to remove what limited a/v functionality there was and leave hooks to 3rd party solutions.
Bearing in mind the Rocket you are using is open source it would be great if you reciprocated and posted your open source work/solution for the benefit of others.
You might also consider building it as an app?
Thank you for your suggestion. I appreciate your constructive feedback.
Actually, we have already almost completed the integration of Rocket.Chat with LiveKit on our own Ubuntu server.
Our main requirement was quite simple: we needed a classroom environment where the instructor could control students’ microphones and cameras, allowing participants to speak only when permission was granted.
However, I would like to clarify something about our project.
Our primary focus is trading education, financial market analysis, and the development of intelligent trading research tools through our Academy.
We are not planning to become developers of social media platforms or video conferencing software. Rocket.Chat and LiveKit are simply supporting technologies that help us provide an interactive educational environment for our students.
We chose Rocket.Chat because it is an excellent communication platform, and LiveKit because it provides the audio and video capabilities we need.
Our objective is to integrate these existing technologies efficiently so that we can concentrate our time and resources on our actual mission: trading research, education, and technology.
I appreciate your suggestion about developing a Rocket.Chat App. It is certainly an interesting possibility, and we may consider sharing reusable parts of our integration once everything is completed and properly tested.
However, maintaining and developing a separate conferencing application is not our main objective.
Thank you again for your advice and for the work that the open-source community contributes.
So you are developing code.
You’ve taken open source code, built your own proprietary code/integrations that you are selling to clients as a whole package, want free help, and don’t contribute anything back. Not a single line of code or help.
Nice. All take, no give. Very sustainable. Very open source. Not. Carry on.
Have you any idea how Rocket should make money to sustain development?
Don’t be surprised when they close the open source code entirely and make it paid licences only…
