Reply Message - Transmission channel
Hello, I would like to know if it is possible to carry out the following
I have the general channel on which I enabled the broadcast-only function, and with permission to react.
However, I wish that read-only users could answer the topic as well. In this case they would not send new messages, they would only react to the message and reply to the topic.
  • Version of Rocket.Chat Server: 2.4.11
  • Operating System: Linux
Thank you very much if anyone knows how to help me
Check here: https://docs.rocket.chat/user-guides/channels#creating-channels
Its sounds like you want just a read-only channel rather than a broadcast channel, once a channel is set as a broadcast channel I don’t believe you can go back to read-only. Your best option is likely to create a new channel as read-only and transfer your users over then delete the old broadcast channel.
